NEED HELP fast. Plug tip broke
Old Apr 30, 2009 | 01:22 PM
dtuned's Avatar
hopefully, it's nothing so you can sell the stock turbo and use it to help pay for the red
Old Apr 30, 2009 | 02:06 PM
evilevo22's Avatar
well did the compression check. the cylinder the tip broke off was number 2 the 135 and 145
first time did 150 135 145 150
second time 150 145 145 150
Now should i just check the turbo
Old Apr 30, 2009 | 02:51 PM
evilevo22's Avatar
bump
Old Apr 30, 2009 | 03:46 PM
dtuned's Avatar
try it a third time and see if the numbers from the second run match. If so, then you're ok. That first run does indicate something happening in cylinder 2. If anything, it sounds like a valve may have suffered a little damage. If you can perform a leak-down check for cylinder 2, this would be a more accurate measurement of cylinder integrity. Make sure that cylinder 2 is a Top Dead Center to do this. Once the cylinder is pressurized, listen for hissing. You can also. If you don't have a leak-down tester, take the car to a garage that does have one and ask for a leak-down test
Old Apr 30, 2009 | 03:49 PM
dtuned's Avatar
You can also build your own leak-down tester
http://www.motorcycleproject.com/mot.../leakdown.html
Old May 2, 2009 | 10:33 AM
evilevo22's Avatar
also what is easiest way to check my turbo exhaust side wheel for damage.
Also how much play is acceptable.
Any other suggestions to figure out what is damaged would be greatly appreciated this is my DD
Old May 2, 2009 | 11:04 AM
sonicnofadz's Avatar
I've seen this a million times on race bikes, 4G63's, honda's, etc. Its not really a big deal at all. 90% of the time the motor just spits it out without harming the exhaust valve, and the fan blade on the turbo takes a little nick. No biggy. I doubt the compression loss you are seeing is due to the broken plug. NO the plug tip is NOT still in your engine lol.
Old May 2, 2009 | 11:16 AM
evilevo22's Avatar
finally some good news.
so time for a new turbo
Old May 3, 2009 | 07:04 PM
Neko723's Avatar
Old May 3, 2009 | 07:57 PM
reyrey's Avatar
when this happened to me i pulled the spark plugs & dropped a few drops of lucas oil stab right down. it burned off for a while. but ive done 3 comp tests & i was in good shape.
Old May 3, 2009 | 11:25 PM
xspsi4's Avatar
Aren't you the guy who just ripped off another member by sending him a glove and a garage door roller in an aem ems box?
I would say the spark plug issue is prolly the least of your worries
https://www.evolutionm.net/forums/ev...ml#post7017571
Old May 4, 2009 | 07:20 AM
typac69's Avatar
+1 on that want to see this one..
Old May 4, 2009 | 10:19 AM
reyrey's Avatar
if you're the scammer, bro WTF!
Old May 4, 2009 | 08:07 PM
FX11's Avatar
wow, thats messed up
Old May 5, 2009 | 10:18 AM
evilevo22's Avatar
i am not a scammer. He is going artound saying things that are not true. He is upset because the outcome but im the one who is out an AEM and now he going around saying things that are not true.
