EVO 9 Oil drain bolt
Old Apr 30, 2009 | 12:25 PM
evogsrz's Avatar
To make a long story short, i bought my Evo 9 used from a local dealer about 3 months ago. Everything was great and i love the car. Yesterday when i decided to do an oil change, i noticed that when i took out the oil drain bolt, it was stripped. The drain bolt and the thread on the oil pan is fawked...My guess is the pervious owner fawked up. Well, right now i want to get it replace. Should i get a new oil pan??? If i do, how hard is it to remove the stock oil pan?? Do I need to get a new oil return line with the oil pan??? Any help would appreicate....Thanks
Old Apr 30, 2009 | 12:29 PM
rolly1818's Avatar
Registered User
depends on what u use the car for. should be an easy change though. i only know 2 options:
AMS has an oil pan for track racing and well OEM. ur choice.
Old Apr 30, 2009 | 12:34 PM
Kings Fan's Avatar
You'll need new gaskets
Old Apr 30, 2009 | 12:37 PM
evogsrz's Avatar
Yes, i know silicone gasket. BTW How hard is it to remove the stock oil pan??
Old Apr 30, 2009 | 12:50 PM
evoracingstar's Avatar
its easy.. there a couple of bolts unbolt it comes right down squirt some rtv around the pan. and thro ur new one on just get a stock oil pan u dont need to spend 100 of dollars on a oil pan which isnt really made for the road and use for the track only... unless u track ur car alot.
Old Apr 30, 2009 | 01:01 PM
evogsrz's Avatar
Has anyone order anything from this site??? I was thinking of buying this oil pan. Is it necessary to buy a "OIL RETURN TUBE" from what they recommend?? Or can i just use the stock??? Thanks
http://www.lancershop.com/customer/p...&cat=15&page=1
Old Apr 30, 2009 | 01:23 PM
Tnnrx7's Avatar
Don't waste your time with LancerShop.
For any OEM parts you need, PM RussellM and / or just get it off his webste:
www.mitsubishiparts.net
Old Apr 30, 2009 | 01:35 PM
AF-Evo8's Avatar
oil return tube is NOT necessary on a IX only if you buy a new oem oil pan for VIII. They stopped makeing the VIII oil pan and the IX's oil pan has a slightly different return location.
Old Apr 30, 2009 | 03:32 PM
MinorThreat's Avatar
What advantage does the AMS oil pan have? is it stronger in case it scrapes the track?
Old Apr 30, 2009 | 04:26 PM
Smike's Avatar
This.
