NEED HELP ASAP leaking ACD bleeder
Old May 2, 2009 | 04:40 PM
ODUB's Avatar
my ACD bleeder screw is stripped, and i need to helicoil it. what size is the ACD bleeder screw? what size helicoil do i need?
Old May 2, 2009 | 06:42 PM
KenMasters's Avatar
Try someone who has shop-key or the service manual. Or try shep or tre trans shops.
Old May 2, 2009 | 10:52 PM
ODUB's Avatar
got the info. kevinD came through again. for anyone who might have this problem in the future, the size of Helicoil you need to fix it is 10 x 1.0
Old Mar 28, 2010 | 08:22 PM
Ryuartz's Avatar
^ Can anybody confirm this? is M10 x1.0 right size for bleeder? Thank you.
Old Apr 2, 2010 | 05:22 AM
Sainax's Avatar
helicoil fixed the thread but the acd fluid is now leaking from the new threads. now what?
Old Apr 2, 2010 | 08:23 AM
Fast_Freddie's Avatar
Veteran: Navy
Maybe some thread sealer around the helicoil upon insertion, then a tad on the bleeder???
Old Apr 2, 2010 | 10:12 AM
Sainax's Avatar
we trying that now. we came up with a new solution they have something called a timesert. www.timesert.com which is like a whole new thread insert instead of a coil. hopefully this one will work
Old Apr 4, 2010 | 03:10 AM
ODUB's Avatar
let me know how it works. i never did helicoil mine, i just plugged the hole in the bleeder screw with a plug from an old set of headphones, then JB welded over it to keep it from moving. it's been holding fine for over a year now, no issues, but I should do something more permanent lol
Old Apr 4, 2010 | 07:14 AM
Veteran: Navy
Timecerts are good, we use them in the aviation community...
Old Jul 26, 2011 | 01:51 AM
05-EVO-GSR's Avatar
Mine is stripped. Any advise would be greatly appreciated.
