Help! Wont Start!!
Old May 4, 2009 | 11:11 AM
EViR's Avatar
Help! Wont Start!!
After adjusting the clutch off the how to clutch adjustment.
My car simply WONT START NOW?!
All i did was use the 12mm and make the rod bigger, now it wont even start?
Not even a click. Everything was fine before i did this..
BAAAAH
Any ideas??
Old May 4, 2009 | 11:16 AM
fvaldes's Avatar
Remember that the clutch pedal has to be all the way down for the car to start, so it is most likely that whatever adjustment you made to the pedal caused this. For sure the trigger is not going ON when you press the pedal thank to that adjustment. Try putting the pedal back to normal and see if that makes it work, if it does you can adjust it a little before causing the problem again.
Old May 4, 2009 | 11:18 AM
Dapper Dan's Avatar
you could have bent the clutch pedal switch so it doesnt get pushed in fully. Unplug it and see if it starts.
Old May 4, 2009 | 11:23 AM
EViR's Avatar
Thanks i just came back inside to say the clutch pedal pushes a switch in and it was bent so i had to bend it back. All better now !!! Yay!
Thanks guys
Old May 4, 2009 | 11:26 AM
Clutchdc5's Avatar
lol, gj
