FP RED injector size?
Old May 5, 2009 | 09:25 AM
Draven83's Avatar
What size injectors is everyone running with their FP RED setup?
Old May 5, 2009 | 09:36 AM
cpoku's Avatar
What is your power goals?
Old May 5, 2009 | 09:46 AM
Draven83's Avatar
400+ hp. trying to run 10's. i thinking 1000 would do fine...but just seeing what everyone else is running
Old May 5, 2009 | 09:49 AM
griffeyr's Avatar
880 on pump
Old May 5, 2009 | 10:00 AM
merv414's Avatar
i am dong 1000's on pump with meth. i have everything im just waiting on my red. its going on 8 weeks. so i should get a tracking number anyday i hope.
Old May 5, 2009 | 10:02 AM
ROGERV's Avatar
1450cc on E85
Old May 5, 2009 | 10:15 AM
chaotichoax's Avatar
that's kind of a broad question
91 pump?
93 pump?
e85?
with or without meth?
it's not as simple as you are looking for it to be...thankfully most responses are including their fuel type
cpoku's Avatar
880 - 1000(meth); at how much boost do you want to run at?
Old May 5, 2009 | 10:16 AM
cpoku's Avatar
91 pump?
93 pump?
E85?
With or without meth?
It's not as simple as you are looking for it to be...thankfully most responses are including their fuel type
+1
romogst's Avatar
1200 cc for 400hp.
Old May 5, 2009 | 10:18 AM
Originally Posted by romogst
1200 cc for 400hp.
again...you can't generalize this
Old May 5, 2009 | 10:58 AM
gsrboi80's Avatar
For 93 pump gas hell even with a tune for race gas 880's will be plenty. Now if your looking to run the corn your gonna need something bigger.
I'm on 61mm BB and I run 880's 26psi on 93 pump and EVOSCANS IDC's barely tickle 80. Im sure with race gas at 30psi I'll still be way ok
Old May 5, 2009 | 11:48 AM
Jedi_Gill's Avatar
FCOTM Winner
880 are more than enough.. If you want to go bigger, You're going to run into some driveability issues on the stock ECU. Unless you're going to run E85 stick to 880's for pump and race.
Old May 5, 2009 | 11:53 AM
kanyonkid's Avatar
i dont have my red yet,but im gonna stick with my 780's... 93oct under 25psi
Old May 5, 2009 | 01:16 PM
EvoDom's Avatar
1000cc
