HELP with a starter problem
Old May 5, 2009 | 09:02 PM
izabran's Avatar
ok so... i installed a exedy twin disk HD on a evo...
and since then i've destroyed 3 starters...
the car would grind then start... then after i cut it off... it would just grind...
everythign is installed proper... at first i thought it was the upgrades...
it has just got hks cam,35r kit,1000cc inj installed...
and it just keeps killing starters... also has a mini battery... any one have any idea why...
it feels like it wont spin the flywheel..
Old Mar 2, 2011 | 02:11 AM
F0RSAKEN's Avatar
Bump, this is my exact problem.
Old Mar 2, 2011 | 07:09 AM
izabran's Avatar
Hey it was my starter bolts they werent going in right...so the starter had play...
Old Mar 2, 2011 | 12:54 PM
F0RSAKEN's Avatar
Hey it was my starter bolts they weren't going in right...so the starter had play...
Just put new OEM bolts in and it still does it Now it sounds like its intermittently engaging and disengaging, like the starter isn't fully meshing with the flywheel.
I've tried 2 starters, and both are good on my other Evo, so I know that isn't the problem, and I've also tried 2 different starter relays. Still nothing.
Anyone have any ideas at all?
EDIT: The starter plate IS bent where the starter bolts up, up inside where it doesn't brace against the transmission, but the starter bolts up and sits flush. Could this be the problem, and if so, is it possible to replace it without completely removing the trans? I've done 2 clutches in 2 weeks and I'm a bit spent.
shrtstuff89
May 6, 2021 02:41 PM
GrandmasterCow
Apr 1, 2013 05:33 AM
1 WICKED EVO
13
Jun 29, 2010 02:50 PM
tianma_evo
Jan 28, 2010 08:08 PM
VTEC Killer
May 21, 2004 09:49 AM
