Clutch Bleed?
Old May 6, 2009 | 09:04 AM
aguita's Avatar
Clutch Bleed?
I cannot seem to find how to bleed the clutch line..Does Anyone knows how to?
thanks
Old May 6, 2009 | 09:11 AM
Mr. Evo IX's Avatar
2 people, much like bleeding brakes. Pump clutch and hold to the floor while someone opens and closes the bleeder on the slave cylinder. You will have to pick up the clutch pedal after each bleeding manually as it will be left in the depressed position. Repeat.
tips:
Attach a hose to a 16oz soda bottle to the bleeder valve so it doesnt spray brake fluid.
Use a line wrench on the bleeder valve.
