04 Lancer WRC engine bay
Old May 11, 2009 | 04:06 PM
zbomb's Avatar
Interesting huh...If anyone has any other better pics i'd love to see them.
Really small IC pipes...
Anyways, thoughts on the setup.
Old May 11, 2009 | 05:37 PM
stryfetew's Avatar
I'm going to assume this is the new 4b11 power plant?
Old May 11, 2009 | 05:38 PM
stryfetew's Avatar
Correction I can make out it is the 4g but laid out weird.
Old May 11, 2009 | 06:54 PM
KenMasters's Avatar
Anti lag / big *** turbo/ and one heck of a cooling system. It also looks like it is sitting father back and lower and maybe a little different angle. That SOB is bad.
Old May 11, 2009 | 07:34 PM
zbomb's Avatar
Gotta think the turbo in that position is really good for weight distribution....
Wish I had some better pics, I grabbed that one from a screenshot
Old May 11, 2009 | 07:35 PM
heel2toe's Avatar
Definitely an interesting setup. There are a couple of different lines going into the radiator. Also the thermostat housing looks to be in the center whereas on our engines there is a hardline that runs across the back of the block and the thermostat is of the right hand side. Wait a minute. Upon further inspection it looks like there may be a vertical flow intercooler and and radiator on the other side of it. Def would be nice to see some other angles.
Old May 11, 2009 | 07:39 PM
toostar-ish's Avatar
Its a '2004' WRC why would you even assume it was a 4B11 engine...
was the IC smaller than the stock Evo's or the same size?
Old May 11, 2009 | 07:42 PM
Evoardo IX's Avatar
I have better pics, uploading them now...
Old May 11, 2009 | 07:47 PM
Evoardo IX's Avatar
Ok here they are, engie bay, and suspension setup
Old May 11, 2009 | 07:49 PM
heel2toe's Avatar
Give him a break he corrected himself
On a different note do you have any more of it directly in front of the engine bay?
Old May 11, 2009 | 07:50 PM
Evoardo IX's Avatar
I like how the IC is in a vertical possition, and flow to the intake many is almost direct. Antilag setup can't be seen in this pic, I have a pic of a WRC evo 7 where you can actually see the antilag
Old May 11, 2009 | 07:52 PM
Evoardo IX's Avatar
The best I could do
Old May 11, 2009 | 07:54 PM
Rallaro's Avatar
thats gettin a little too similar to subie engine bays
Old May 11, 2009 | 07:56 PM
zbomb's Avatar
From that angle it really shows how far back the motor is tilted...
Thanks for the great pics.
Old May 12, 2009 | 09:00 AM
crcain's Avatar
http://www.lancerregister.com/showthread.php?t=232311
http://www.lancerregister.com/showthread.php?t=97236
http://www.lancerregister.com/showthread.php?t=168643
http://www.lancerregister.com/showthread.php?t=159453
