boost leak test oil cap leaking?
Old May 14, 2009 | 08:13 PM
dtuned's Avatar
That's too bad. It's usually the most simplest things that go wrong and get amplified with the lack of common sense and forgetting that almost anything will follow the path of least resistance.
Old May 14, 2009 | 08:36 PM
dtuned's Avatar
Originally Posted by dxbtune
good read a lot of smart a$$ comments from people who don't know jack
results at the end
https://www.evolutionm.net/forums/ev...e-results.html
Man... I read all of that and as you said... a lot of smart a$$ comments for a simple leak test. A lot of people fail to realize that combustion engines, no matter how well engineered, have slop in them, and that engines at rest will have looser tolerances all the way around compared to an engine that is working due to the process of heat generated. People forget that things expand and contract with temperature changes.
Old Sep 26, 2012 | 11:30 AM
High_PSI's Avatar
Mine just did this last night on a 29PSI pull. The dip stick is still good no puking, lucky me!
Old Oct 12, 2012 | 06:12 PM
connor4200's Avatar
Originally Posted by evo9ben
i decided to check for a boost leak today since i wasent boosting high like im saposed to and i found out air is coming out from around the oil cap? is this normal i was told to check my compression and i got 135 on all cylinders so im good with that but what would you sugjest doing. could this be a turbo seal or something or maybe just get a new cap. is it normal to have air in that area?
no when u do a test take off the cap or it will pressurize the crankcase which possibly couldve broke oil cap seal.
Old Oct 12, 2012 | 06:13 PM
connor4200's Avatar
ghkfdfshafgljkl
Old Oct 12, 2012 | 06:37 PM
connor4200's Avatar
ive been lossin 5 psi and it comes back and then goes away i think my coupler on the turbo inlet is melting but i havnt checked, yet
Old Oct 12, 2012 | 06:44 PM
connor4200's Avatar
results at the end
you are right about that lol there just throwin bull**** out there
kaj
Oct 17, 2015 05:51 PM
4xforce
74
Feb 26, 2013 10:20 AM
ethan169
24
Dec 23, 2011 01:54 PM
BlackSE
Apr 20, 2011 09:28 AM
ball7068
14
Jul 28, 2010 08:44 AM
