compressor surge?!?
Old May 12, 2009 | 06:44 PM
vladdyyy's Avatar
compressor surge?!?
so i installed a greddy rs. its VTA right now cuz i need an recirculating insert and dont have it yet. but its getting compressor surge... at low and high boost. the BOV is on right. ive played with the spring. from all the way loose to all the way tight(spring), im still getting that flutter sound. what could be the problem?
Old May 12, 2009 | 06:46 PM
Macaroni's Avatar
Is the bov new or used? It could be bad.
Old May 12, 2009 | 06:57 PM
vladdyyy's Avatar
used. ima kick the guy in his face if its bad.
Old May 12, 2009 | 06:59 PM
Macaroni's Avatar
Most bov's will flutter if they are bad or if the spring isn't adjusted right but you said you adjusted it from one extreme to the other and it still does it. Can you press in the valve with your fingers?
Old May 12, 2009 | 07:15 PM
Babs's Avatar
check to make sure the valve isn't stuck closed...also check your vacuum lines and make sure they are snug and not leaking
Old May 12, 2009 | 09:32 PM
vladdyyy's Avatar
cant push the valve in with my fingers.... there is a blow of air but the compressor surge flutter sound at the same time....i found a hole in the vacuum line. ill change that tomorow and see if it does anything. i dont see how it would....
Old May 12, 2009 | 09:45 PM
project_skyline's Avatar
could also have the wrong vacuum spring.
Old May 12, 2009 | 09:47 PM
vladdyyy's Avatar
what do you mean?
Old May 12, 2009 | 09:54 PM
vladdyyy's Avatar
i know i need it fixed. but how?!
Old May 12, 2009 | 09:56 PM
Boost3dxEvO's Avatar
that is a major problem... vacuum leaks are no good.. if you are running the stock maf with this bov at VTA, that will also cause problems.. wait on the recirculation kit and fix the vacuum leaks via a boost leak test.. and then see if it still does it when you adjust the bov to a softer setting..
Old May 12, 2009 | 09:59 PM
vladdyyy's Avatar
what will happen if i cant push the valve in with my fingers? does it mean its stuck or the spring is too tight?
Old May 12, 2009 | 10:13 PM
vladdyyy's Avatar
ok so im taking it apart right now. diaphragm is ok. two springs. im gonna take the inner spring out(smaller of the two). and see how that works. changing vaccuum lines tomorow. gonna run it VTA for a lil see how that goes. still waiting on the recirc.
Old May 13, 2009 | 03:44 AM
Macaroni's Avatar
If you can push it in with your fingers that lets you know how stiff it is. You shouldn't be able to so your good.
Old May 13, 2009 | 07:02 AM
cfdfireman1's Avatar
Don't even mess with it till you get the recirc for it, you're just wasting your time. Put the stock one back on.
Old May 25, 2009 | 02:55 PM
vladdyyy's Avatar
Okay so I got recirc in. I'm still gettin compressor surge sometimes. Mostly at higher boost. Did the single spring mod too. ??????!!!!!!
