RPMs drop 500 during WOT in 4th and 5th, why?
Old May 13, 2009 | 05:29 PM
LakerRaider's Avatar
Originally Posted by cfdfireman1
how could this be possible? please tell me the physics behind it.
it wasnt meant to be literal, a car could jerk and not be goin anywhere (dies), it happened a lot while we were all learning to drive manual
Old May 13, 2009 | 05:31 PM
Originally Posted by bbyevo8u
it might be your spark plugs, check them! how many miles on your car?
i have about 36k miles on the car, but changed the plugs about 6000k miles ago
Old May 13, 2009 | 05:37 PM
PVD04's Avatar
It's the clutch. While your tach is going up and the speedometer is going up it's not going up as fast as it should. The only way the tach can drop without the car changing speeds is if the clutch is slipping.
Old May 13, 2009 | 06:04 PM
idk if this guy explained it better than myself but no one on that thread seems to be blaming it on a clutch
Old May 13, 2009 | 07:27 PM
PVD04's Avatar
That's because the people in the two threads you linked have different problems. Neither one of them have the tach dropping 500 RPM without the car slowing down.
Old May 13, 2009 | 07:51 PM
21Evo-lution's Avatar
Clutch slipping! Same as mine!
Old May 13, 2009 | 09:30 PM
actually I just got a pm from the guy with the x that it was happening to and he said that the load values were set too low so there's my answer! Sorry buddy, as much as ur dying for my clutch to go out, I guess it isn't the clutch afterall haha. Did something happen in your driving past that's causing you post traumatic clutch syndrome?next time u hear the smallest noise while driving ur car, chances are it isn't your clutch man!
Old May 13, 2009 | 09:31 PM
TTP Engineering's Avatar
Originally Posted by PVD04
Sounds like your clutch is slipping but instead of noticing the slip, you just see the RPMS dropping back down as the clutch starts to grab. If you go out and try this again, check to see if the tach starts going up without the speedometer going up.
Old May 14, 2009 | 09:59 AM
Mr. Evo IX's Avatar
So you think your hitting boost cut now? Did your car hit boost cut before your clutch started slipping?
Old May 19, 2009 | 12:50 PM
cfdfireman1's Avatar
LakerRaider
Tell us how much your speed drops when this happens in 5th gear.
Wait wait, disregard I just found this. WTF???
https://www.evolutionm.net/forums/7071486-post45.html
Old Aug 7, 2014 | 12:10 PM
LiX's Avatar
LiX
I seem to have the same issue! RPMs are dropping when I step on it on 3rd, 4th or 5th gear while I'm cruising and after 1 sec continue to accelerate. Does not seems to be fuel cut as the car is not stopping, it just delays the acceleration.
Is it confirmed that the issue is caused by the clutch?
Have in mind that the car is bone stock GSR.
Old Aug 7, 2014 | 12:16 PM
SilverShadow03's Avatar
Yes, Click on the link in the post before yours...the OP states he is in need of a clutch.
Just like everyone in this thread had originally said back in 2009.
Bend over and get ready to hike the wallet like cfdfireman1 said...LOL
Old Aug 7, 2014 | 12:27 PM
LiX's Avatar
LiX
I sent him PM, but no reply... that's why I wanted to be sure.
Old Aug 7, 2014 | 12:34 PM
Keep in mind you are bumping a 5+ year old thread....You might want to start your own thread or post in a more recent clutch related thread and post your question there.
Old Aug 7, 2014 | 12:42 PM
LiX's Avatar
LiX
Ah... sorry about bumping the thread, however it was top suggestion from google for my search criteria.
