Cost of coolant flush?
Old May 15, 2009 | 04:26 PM
evolucion's Avatar
I think it's time to get my coolant flush out. I've had this car for about 4 years now, got about 33k on it. I've never done this before and haven't find any useful tutorials to help out. I did some google search and found tutorials on other cars, but not evos. I'm quite surprise that there is no picture turorial about this topics. So if I decided to have a shop do it, how much would it normally cost?
Old May 15, 2009 | 04:31 PM
orangeorphan's Avatar
I just got my evo, but with my lancer it was simple. There is a valve on the bottom of the radiator, turn it, and the fluid comes out. Close the valve and pour the new fluid in through the top.
Old May 15, 2009 | 04:40 PM
Evoryder's Avatar
Just do it yourself. Takes about 1hr...super easy to do
Old May 15, 2009 | 04:41 PM
Evoryder's Avatar
Proper way is to add distilled water with car a/c on max temp.
Old May 15, 2009 | 07:12 PM
klever's Avatar
Normally the price should be $25-30 for a standard flush, shop around.
Old May 15, 2009 | 07:29 PM
bbyevo8u's Avatar
where is the block drain plug? i tried looking for it but couldnt fing it
i need to do mine also
Old May 15, 2009 | 07:38 PM
rcheung's Avatar
The drain plug is under the radiator. Just about any tutorial with a drain plug in the bottom of the radiator and filler neck at the top of the radiator should do.
Old May 15, 2009 | 08:17 PM
felickz's Avatar
Block drain plug is below the intake manifold... looks like a B*tch to get to... anyone have any advice to removing that?
If you simply drain your fluid and fill up, your not "flushing" the system..
Old May 15, 2009 | 11:08 PM
Evoryder's Avatar
THe radiator drain plug is right off the base of the radiator. 10mm deep socket/ wrench to get it off.. Easily visible from under car.
Old May 15, 2009 | 11:46 PM
Spish's Avatar
I thought it was the heat?
Old May 16, 2009 | 08:25 AM
bbyevo8u's Avatar
is it ok to drain the radiator but not the block??
is it bad to mix old coolant with new coolant??
Old May 16, 2009 | 08:28 AM
kilgoja's Avatar
just take it in and pay the $30...alot easier that way...lol
Old May 16, 2009 | 09:13 AM
SpinninAll4s's Avatar
So is the plug by the intake mani or located on the raditator ? I should do a coolent flush to...
Bumpity.
Old May 16, 2009 | 10:37 AM
Stealthmatt's Avatar
I too would like to know how to change the coolant in my evo 9...any one got any pics or anything?
also does a coolant flsuh mean they just drain and replace fluid or do they run a stream of water through the system to clear any deposits?
Old May 16, 2009 | 10:43 AM
detroit pistins's Avatar
u can do that urself with a gallon of distilled water when u flush it. just remove the bottom rad hose, drain the original fluid, and while its open pour in another gallon to completely flush the system or actualy use a garden hose, for few mins. then fill up and close.
