Modding?
Modding?
Is their like a post on what to modify in order for best performance?
Im just curious on what i should modify next.
Currently i have:
TBE
HKS 272 Cams
780 AMS Injectors
AMS Fuel Rail
Forge Recirc. BOV
MBC
ZR-2 Lowering Kit
SAFC II
AMS Intercooler
(Needing a tune, will be performing shortly.)
Currently i have:
TBE
HKS 272 Cams
780 AMS Injectors
AMS Fuel Rail
Forge Recirc. BOV
MBC
ZR-2 Lowering Kit
SAFC II
AMS Intercooler
You dont really need the SAFC II if your getting a tune (ECU). Best performance would be an upgraded turbo. Preferrably Green, Red or BBK.
Also I hope you got an upgraded fuel pump. If not then that should be your priority right now.
I would agree you would want a fuel pump for the injector upgrade. What are you want to do with the car?
If you are planning on launching the car then,
I would think solid engine mounts? or engine damper, & front LSD to eliminate wheel hop.
I have an 8 also, and just got the following mods:
Helix Cam Gears
255lph Fuel Pump
Perrin Fuel Rail
BC 272 cams
JAM lifters
RC Engineering 750cc
GSC Valve spring/retainer
Cometic headgasket
Arp Headstuds
Perrin Lightweight Pulley
Wavetrac Front LSD
Solid Engine Mounts
o2 housing
ebay intercooler w/lower pipe
Flash Tuned for 91
Car pulls much harder. Now I am ready for a turbo, but I can't afford it.
I also have a SAFC 2 which I use to help with idle issues when AC is on.
Helix Cam Gears
255lph Fuel Pump
Perrin Fuel Rail
BC 272 cams
JAM lifters
Cometic headgasket
Arp Headstuds
Wavetrac Front LSD
Solid Engine Mounts
o2 housing
Flash Tuned for 91
i just got my cable and now im about to start loggin and tuning!
