Differences between evo 8 and 9 J-pipes
Old May 20, 2009 | 01:58 PM
silverex's Avatar
My buddy bought a turbo that "supposely" came with a 9 j-pipe but when you hold it next to a 8 one they look the same. Can you easily tell the difference between the two or is it hard to tell. If anyone has pics of showing both of em would be great
Thanks
Old May 20, 2009 | 02:03 PM
kwanza's Avatar
I believe they are the same. The only difference between the 8 and 9 was the turbo nozzle, mivec, and acd, i think...
Old May 20, 2009 | 04:12 PM
silverex's Avatar
I thought you had to switch to a 9 j-pipe if your runnning a evo 9 style turbo? If not why do venders sell the j pipe with a "evo 9 turbo install kit"?
Old May 20, 2009 | 04:14 PM
silverex's Avatar
What is the turbo nozzle?....i would think it is the j pipe?
Old May 20, 2009 | 04:19 PM
accident's Avatar
they aren't the same. the one for the 9 is a little shorter to make up for the bigger comp housing.
ROGERV's Avatar
The j pipes are different. If you plan to run a 9 turbo on an 8 you have to get the 9 j pipe.
The 8 j pipe hits the starter when using it on a 9 turbo.
Old May 20, 2009 | 04:21 PM
scumrat's Avatar
yep^ i experinced this first hand on my 9 and it fried the battery cable.Cost $300 and a month waitng from japan.I bought a 9 turbo after the 35 was gone,wouldnt you know the j pipe hit the starter.I guess the guy i got it from had it on a 8
Old May 20, 2009 | 04:26 PM
chaotichoax's Avatar
to clarify what you just said make no sense
regardless of whether you used a ix turbo on an viii or a ix you'd need a ix j pipe
it wouldn't make a difference so clearly you had an install error or another problem entirely
Old May 20, 2009 | 04:29 PM
Evoryder's Avatar
9 turbo requires 9 J pipe as stated, regardless of evo 8/8.5/9
Old May 20, 2009 | 04:57 PM
silverex's Avatar
got it.....you need a 9 j pipe for 9 type turbos.
But can your easly tell the difference?
OT:I bet my buddy got the 8 pipe with it cause it does hit the starter......untill i massaged it with a hammer
seven10
Nov 29, 2016 09:42 PM
3v0luti0n
May 16, 2015 10:43 AM
Evo23IG
Oct 21, 2012 03:52 PM
33bull
Jan 7, 2009 10:22 PM
Sansone
13
Jan 7, 2009 03:14 PM
