Clutch Vibration???
Old May 20, 2009 | 05:13 PM
jbergmeier's Avatar
Clutch Vibration???
So im trying to figure out a issue with my car. My clutch Peddle Vibrates till about halfway pressed down, once down no vibration. Upon further Looking into it, I had the car running looking at the clutch and Throwout bearing though a accsess hole, I noticed a slight "wobble" I also can feel it on the Clutch fork. Not sure if just the Throwout bearing is vibrating, or if the Pressure plate is as well. I have a e*edy Triple Pull Carbon with about 400miles on it, and same on the TOB. Looking at the crank pulley side, there is no "wooble" Also note I have a SOLID front and rear motor mount. I allso had the clip on the PP fall off one time while installing trans, fi*ed it and put it back on. I dont remember when this started doing this. And I dont think the Flywheel ore PP could come lose as I TQ them right and use both blue and Red locktight. So anyone have some Ideas it shifts, Idels and drives fine. Motor is built and no shafts So not sure if this would be "normal" for such a race car like setup. Chime in shops as well.
Edit:
I was down on Fluid for a while as well... Fixed that over the winter and I think thats when this started happening as I cant recal it doing it before, so maybe I bent something?? like the TOB?
