Cylinder bore type and pistons needed
Old May 23, 2009 | 09:08 AM
soldave's Avatar
Well I finally got this oil pan dropped and managed to check out the cylinder bore markings on the bottom of the block. I have managed to source a set of brand new type II pistons I could use but I think I'm out of luck as I think it's type III that I need. Basically, the markings on the underside are as you can see here (if I am looking up from below):
Am I right in thinking those markings would refer to the piston type required for each cylinder as I am looking from the bottom (i.e. cylinder 4 needs type II and cylinder 3 needs type III)? Am hoping this is not the case and that it refers to the cylinder type going in ascending order from the right to left or down the length of the block, but kind of expect that it is. Any thoughts would be appreciated
Old May 23, 2009 | 09:17 AM
TTP Engineering's Avatar
Um no. There is no such thing as piston type.
It's interesting that you found a part that doesn't exist.
The markings refer to bearings used for the MAINs and RODs.
Old May 23, 2009 | 09:19 AM
soldave's Avatar
Well according to Mitsubishi Japan, there is. Pistons for the Evo I and others have 3 types for standard (A, B, and C), as well as offering various types of overbore pistons.
It also hints at it in this post:
https://www.evolutionm.net/forums/3769493-post5.html
Old May 23, 2009 | 09:38 AM
Old May 23, 2009 | 09:40 AM
Originally Posted by soldave
Well I finally got this oil pan dropped and managed to check out the cylinder bore markings on the bottom of the block. I have managed to source a set of brand new type II pistons I could use but I think I'm out of luck as I think it's type III that I need. Basically, the markings on the underside are as you can see here (if I am looking up from below): Firstly, am I right in thinking those markings would refer to the piston type required for each cylinder as I am looking from the bottom (i.e. cylinder 4 needs type II and cylinder 3 needs type III)? Am hoping this is not the case and that it refers to the cylinder type going in ascending order from the right to left or down the length of the block, but kind of expect that it is. Any thoughts would be appreciated
Its cylinder BEARING BORE, not cylinder bore having anything to do with pistons.
Old May 23, 2009 | 09:45 AM
soldave's Avatar
Still doesn't explain the difference between the 3 types of standard pistons available for the Evo I (and other models). And the roman numerals refer to the cylinder inside diameter size.
Old May 23, 2009 | 10:04 AM
GPTourer's Avatar
I can't see your picture, but do you have any corresponding part numbers? What do the dealers in Japan say?
Old May 23, 2009 | 10:08 AM
soldave's Avatar
Part numbers give a Standard A, B and C type which have part numbers MD313285, MD313286 and MD313287 respectively. Tuning shop I tried in Japan today said there were different types but I haven't been able to speak to anyone since I dropped the oil pan this evening and checked out these inside diameter marks.
My mistake on the cylinder bore marking comment initially - I meant cylinder inside diameter.
Old May 23, 2009 | 10:17 AM
GPTourer's Avatar
Well, I hope you can get to the bottom of it, as I would like to know the answer. I had always thought it was because they sold standard pistons in ten, twenty and thirty overbore.
Old May 23, 2009 | 10:21 AM
+.20, +.40 and +.60
85, 85.5, 86, 86.5mm
Old May 23, 2009 | 10:36 AM
GPTourer's Avatar
Originally Posted by TTP Engineering
+.20, +.40 and +.60
Err, yeah, that's what I meant.
Old May 23, 2009 | 05:14 PM
soldave's Avatar
Yes, the pistons are also available in oversize by 0.25, 0.5, 0.75 and 1.0 according to the Mitsubishi parts system, and these parts have part numbers MD300040, MD313291, MD300042 and MD313292 respectively.
Old May 23, 2009 | 05:23 PM
They have nothing to do with your original post requesting what the numerals on the bottom of the block meant.
Old May 23, 2009 | 05:25 PM
soldave's Avatar
Correct. I was adding comment to the post which was above mine about overize pistons. As the user asked for the part numbers of the standard pistons, I also thought it might be useful for him to have the part numbers for the oversize ones from Mitsubishi.
But back to topic, you've no idea about the Roman numerals and which exact cylinder is represented by which number?
Old May 23, 2009 | 05:27 PM
None of the numbers have anything to do with cylinder bores as we already stated.
They are referring to the bores of the mains and bearing sizes.
