Oil leak need help!
Old May 26, 2009 | 10:14 AM
03blkevo's Avatar
Oil leak need help!
I stripped the banjo bolt for oil feed line. The one that goes from the head directly to the turbo. Well it leaks a lil bit does any1 have suggestions on what my course of action should be.
i installed new banjo bolt, washers, re tapped (straight), it is still leaking. if i change the banjo bolt again is there a risk of ****ing up the head permanetly?
