what sensor is this....???
Old May 26, 2009 | 02:46 PM
brandon1304's Avatar
The sensor is located Under the throttle body on the drivers side... with the trans removed it is right behind the flywheel on the upper right hand side.... The sensor has piece of metal on it where the female end attaches... a socket flew off while taking the transfer case and broke the sensor in 2 peices.. thanks for the help!
Old May 26, 2009 | 02:52 PM
bevolucion's Avatar
sounds like the knock sensor, is it attached to the block?
RoadSpike's Avatar
Well far as I know there are only two plugs on the throttle body.
Top one is the throttle position sensor.
Bottom one is the Idle air control valve plug.
Old May 26, 2009 | 03:08 PM
it is not attached to the throttle body.. it is going into the block...right under the throttle body
i also thought it might be the knock sensor...but i ordered an OEM one and it is definately not it ,,,
Old May 26, 2009 | 03:11 PM
hmm
Old May 26, 2009 | 03:16 PM
tkklemann's Avatar
Coolant Temp Sensor?
Old May 26, 2009 | 03:39 PM
hmm maybee
Old May 27, 2009 | 06:10 AM
bumppp..help please
Old May 27, 2009 | 09:33 AM
RoadSpike's Avatar
Why not take a picture of the busted sensor and/or location.
Old May 27, 2009 | 04:20 PM
dsevo's Avatar
Its probably the oil pressure sensor.
Old May 27, 2009 | 04:25 PM
KcEvil8's Avatar
crankshaft position sensor?
Old May 28, 2009 | 11:45 AM
i am thinking it is the oil pressure sensor
Old May 28, 2009 | 11:54 AM
RoadSpike's Avatar
I grow some weary of this hide and seek game is this the sensor and if not circle the right one. Highlighted sensor is the egr solenoid.
Old May 28, 2009 | 06:14 PM
EatSleepBoost's Avatar
if there is one prong coming off of it, and one wire going to it, its round, and a lil corroded. its ur oil pressure sensor. all evo's need new ones eventually anyways to cure the oil light flicker concern so just throw one in. they are only about 20$
Old May 29, 2009 | 07:49 AM
yeah it is one wire with one prong... def. the oil pressure sensor... where can i buy one???
