Normal Idle
Old May 27, 2009 | 07:45 AM
BEISSEN's Avatar
Normal Idle
OK I need some advice/pointers I did a search and could not find what I was looking for. I would like to know what a stock evo Idles at first,Then what is a normal range with Comp Cams. After my tune I am Idling at 980-1030+/-. I never had the car before the cams were installed so I can't answer my own question. What I saw 995 of the time was people talking about Adj Cam Gears with -1 etc etc... So any help would be greatly appreciated.
Old May 27, 2009 | 08:01 AM
YogSaahoth's Avatar
Veteran: Army
i think i used to idle at about 900-950 before cams. after cams go in, ur tuner usually will adjust the idle level to allow it to run a bit smoother, most often resulting in a slightly higher idle..varying according cam specs of course. your idle level sounds normal however
Old May 27, 2009 | 08:03 AM
BEISSEN's Avatar
Ok and I shoud have added I am runiing Comp Cams 272/272 my bad.Thanks for the info wanted to make sure.
Old May 27, 2009 | 08:11 AM
EvoTio's Avatar
On my 03, I was idling at 800 rpm with my stock cams. With my HKS 264/272 cams, I am at a 1000 rpm idle.
Old May 27, 2009 | 09:15 AM
YogSaahoth's Avatar
Veteran: Army
i use hks 272, so there are minor differences between the two...again though, ur idle sounds just right
BEISSEN's Avatar
Ok thanks I just wanted to make sure I did not have anything to worry about.
Old May 27, 2009 | 09:56 AM
Fast_Freddie's Avatar
Veteran: Navy
I have the Comp 272s and my idle is set at 1023
Old May 27, 2009 | 10:15 AM
BEISSEN's Avatar
Does it move a little with the looping I cant see it on the dash I am monitoring it with the HKS TT Type-1 with the Crankshft Sensor/RPM wire tapped on the ECU.So I can see it flux some.
Old May 27, 2009 | 11:02 AM
Veteran: Navy
Yeah it will fluctuate from 1000 to 1061 depending on the lope and when the fan kicks on... it normal...
Old May 28, 2009 | 05:25 AM
BEISSEN's Avatar
Ok thanks.
Thanks for all the help I'm glad I have nothing to worry about.
cts4g63
20
Jan 15, 2024 11:12 PM
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
ryan010
35
Oct 2, 2016 08:54 AM
nothere
Feb 10, 2010 06:25 PM
Fitz
Sep 10, 2007 09:00 AM
