Water temp overheat
Old May 27, 2009 | 10:50 PM
FX11's Avatar
Exclamation Water temp overheat
Hey guys,
I just finished a clutch job, everything shifts fine and stuff, but my water temps slowly climb to critical levels
It goes from 140 and then escalates all the way to about 215+ in about 3 minutes
my oil temps are normal
any help???
Old May 28, 2009 | 06:44 AM
FX11's Avatar
bump
Old May 28, 2009 | 09:04 AM
C6C6CH3vo's Avatar
What are you using to measure coolant temp?
The thermostat should keep the temp between 185 and 197F when warm. I use OBDII data for coolant temp logging, I have never seen over 197F but it reaches that temp many times on a drive.
Nevertheless, need to know how your measuring the temp first to see if that actually IS 215F.
If so, might be low coolant or air trapped in the system. It's quite a processes to properly refill the coolant system without inducing air BTW
Old May 28, 2009 | 07:04 PM
FX11's Avatar
i have a gauge into my koyo radiator
i was using cheap-o coolant so im going with some better stuff and flushing it out tomorrow
Old May 28, 2009 | 09:36 PM
barneyb's Avatar
4 possibilities:
1. Engine full of air
2. Stuck thermostat
3. Fan not working
4. Blown head gasket
