No power to fuel pump!?
Old May 28, 2009 | 09:29 PM
NJ_EveOhVIII's Avatar
Question No power to fuel pump!?
its the big night and we finally finished putting the new engine in. it cranks but theres no power to the fuel pump. where are the grounds for it or fuses or any other power supply for the fuel.(we dont hear the fuel pump)
Old May 28, 2009 | 09:37 PM
borievoinitialD's Avatar
There is a mysterious denso fuel relay somewhere that control the low and high voltage settings on the pump... you could try searching for that here and see if you get any good results..
Old May 28, 2009 | 09:41 PM
uhhh is it a myth or like does it actually exsist plus i didnt touch the fuel pump itself. so whatever grounds or power supply that are in the engine bay would be helpful to have a pointing finger.
Old May 28, 2009 | 09:42 PM
Draven83's Avatar
replug everything into your pump. and make sure all plugs on it are secure. took me 3 hours to figure mine out and thats all it was...
Old May 28, 2009 | 09:49 PM
we didnt touch the fuel pump though. so where are any other fuel pump wires or relays?
Old May 29, 2009 | 12:41 PM
can someone point me to the directions of any grounds for the fuel?
Old May 29, 2009 | 04:51 PM
boscoyo's Avatar
The relay is against the firewall on the passenger side of the vehicle to the right of the braking system.
