Evo 8 to 9 engine swap
Old Dec 27, 2010 | 12:36 PM
  #136
vince_w2004's Avatar
Just food for thought:
After i completed my swap, I threw a P0462 code. Fuel Level Circuit Low Input. It goes away after my tank is half empty. But if I fill up all the way it comes back.
I have a Walbro that is bout to be installed but wondering if anyone has had this code thrown that has done the Mivec swap.
Old Mar 24, 2011 | 09:57 PM
  #137
josevane13's Avatar
does anyone know the model number or anything on that 2nd relay i a lready know its a acd pump relay but i have no serial numbers or model #s a pic would reaaly help thanks
Old Mar 25, 2011 | 12:50 AM
  #138
eddievo8's Avatar
Email me. Can't seem to upload the pics...
Edan113@yahoo
Old Mar 29, 2011 | 06:41 PM
  #139
I am almost certain that the extra ''2nd'' relay is for Mivec and not for the ACD pump.
Can anyone confirm?
Old Mar 29, 2011 | 07:56 PM
  #140
kekek's Avatar
Can anyone confirm?
I thought it was too. Quite sure now that it's for the ACD pump. There is a large white wire w/red stripe that connects to the battery terminal and that relay. If you look at the OCV for the Mivec there are only small wires (low current draw) to power it. If you look at the ACD pump it requires alot more current, hence the larger (smaller gage) wires.
Ultimately you should be able to confirm what it's for by looking at the electrical schematics in the FSM.
Old Mar 29, 2011 | 09:34 PM
  #141
That makes since. I always wondered why my IX harness had an extra wire running to the battery.
Old Apr 5, 2011 | 09:00 PM
  #142
blue8's Avatar
not woth doing at all
Old Apr 5, 2011 | 09:01 PM
  #143
blue8's Avatar
no point
Old Apr 6, 2011 | 02:02 PM
  #144
Originally Posted by blue8
no point
STFU!!!
Old Apr 25, 2011 | 01:53 PM
  #145
xsh0rtyduw0px's Avatar
i have a whole 9 motor swap im selling if anyone interested including engine harness
Old May 18, 2011 | 06:03 PM
  #146
the mark w's Avatar
I know I'm late but the swap is easy. We did it in our shop car, just ran v manage to control mivec, still on the evo 8 ems. No real extra wiring needed.other than the obvious engine harness just for ease of instal
Old Aug 24, 2011 | 04:22 PM
  #147
eddievo8's Avatar
Hey guys,
I recently did this swap, i tried disabling the immobilizer code and the car still would not turn on. The engine cranks, but doesn’t turn on completely...any ideas on what the problems might be?? I rechecked the harness and everything seems to be installed correctly. on my dash a green "key" icon flashes...the locksmith said that i have to take it to the dealer to get a "module program" on the entire car...
Any thoughts...
Old Aug 26, 2011 | 11:47 PM
  #148
st00pidct9a's Avatar
nice
Old Sep 3, 2011 | 08:57 AM
  #149
eddievo8's Avatar
woooh finally i got my baby starting and running! thanks to all the people posting here!!!
Old Sep 5, 2011 | 06:23 PM
  #150
Astro_Train's Avatar
Veteran: Navy
lots of good info here for the swaps!
I have a questions that is ECU related that maybe someone can answer...
The ECU in my 8 is toast, my 8 has no ACD(its an 04), if I pick up an 8 ECU from an 05 w/ ACD, will it work with my 8 that has no ACD? or does it have to be an 03 or 04 ECU?
