35r install. Oil and Coolant Lines.
Old Jun 1, 2009 | 12:05 PM
crckheadjed's Avatar
Doing a 35r install with peakboost manifold and 02 housing (mounts to stock dp location) Wondering if i will need to fabricate new oil and coolant lines or does a company offer replacement lines that will work, OR will stock lines work???
Old Jun 1, 2009 | 02:03 PM
yuronich_b's Avatar
You'll need to get some hose to hook up the coolant lines and you'll probably want to find a solution for the oil return line off the turbo. The flanges are slightly different on the turbos. When I installed my RNR 50 trim kit I made up a stainless tubing return line with AN fittings and used the flange that slow boy racing sells for a mitsu oil pan with AN threads already...
Old Jun 1, 2009 | 02:21 PM
CO_VR4's Avatar
Peakboost makes SS lines for their kits. Not cheap, but well made.
FP has a drain line kit with CNC fittings and Aeroquip "blue" hose for a much lower price than SS lines. Works just as well. Also have the Tial banjo fittings for coolant lines.
Your call.
Old Jun 1, 2009 | 07:53 PM
justboosted02's Avatar
www.extremepsi.com has oil and coolant line kits for a good price
