Replacing the Front O2 sensor
Old Jun 4, 2009 | 04:49 AM
AbrasEvo's Avatar
Can I replace the front O2 sensor with a wideband on the stock ECU?
Old Jun 4, 2009 | 05:22 AM
Gary@MellonRacing's Avatar
i dont understand the quiestion ...
u want to know if u can use a wide band sensor in place of a front o2 sensor .. answer NO
u r asking cause u have a damaged front o2 sensor right ????
Old Jun 4, 2009 | 05:26 AM
JakeTheVIII's Avatar
Not only will it throw a code, I think that's a little too close to the turbo for a wideband. I think they usually say it's supposed to be a certain distance from the turbo, right?
Old Jun 4, 2009 | 05:32 AM
partyboy1122's Avatar
You can replace the Front 02 with another Front 02.
I placed my Wideband o2 sensor in the stock rear o2 bung.
WB's must be 12-13'' away from the turbo.
Old Jun 4, 2009 | 05:40 AM
AbrasEvo's Avatar
No I didn't damage it I'm just midway into a turbo swap and about to get the o2 bung welded in and was wondering if I could throw my extra UEGO on instead.
Old Jun 4, 2009 | 05:53 AM
OhsixIXBish's Avatar
Anser is no sir. The front 02 bung is to close as its been metioned. Ull either burn ur 02 up in the wideband and or it wont read correctly.
Old Jun 4, 2009 | 10:42 AM
SWOLN's Avatar
The answer is YES ! Go to the Ecuflash forum, and there is a how to. Try this : https://www.evolutionm.net/forums/ec...o2-system.html
DONNOD
Jul 22, 2016 05:16 AM
KJS
Nov 28, 2013 11:06 PM
iXac
Evo X How Tos / Installations
Jun 20, 2012 10:03 AM
chrisw
May 18, 2010 07:51 AM
evilevo22
Oct 3, 2007 02:36 PM
