2.4 storked to 2.7?
Old Jun 4, 2009 | 10:16 AM
zlthomason's Avatar
2.4 storked to 2.7?
hey guys i currently have a 2.3 stroker and was thinking about doing a build you havent really heard of. i was going to get the 4g64 short block and use the heads off of my 4g63 with the 272 cams and stroking the 2.4 short block to a 2.7. if anyone has already done the heads on a 2.4 short block do the heads bolt right up?i dont plan on starting till after i get back from bootcamp when i have a decent sign on to play with but let me know what you guys think?
Old Jun 4, 2009 | 10:22 AM
CAD EVO's Avatar
That would be so sick, full spool on an HTA35R at 3000rpm!!!
Old Jun 4, 2009 | 10:44 AM
project_skyline's Avatar
Its been done before IRC, but there isn't a whole lot of information and it was using the BC kit which a lot of people look down upon because the chinese used internals.
It would be cool to see someone do this with good parts and have it come out good. I would think it could put out some serious torque.
Old Jun 4, 2009 | 10:46 AM
yahh's Avatar
I though about doing it since my Eclipse is a 4g64. I just haven't figured out how much it will run me, and I would rather go FI before doing the head swap.
Old Jun 4, 2009 | 10:47 AM
GPTourer's Avatar
Its been tried/done, but not to any earthshattering results to my understanding. The redline on such a monster is compromised and the rod angles are so severe that its not a very desireable build in concept to begin with.
Old Jun 4, 2009 | 11:03 AM
zlthomason's Avatar
well i kinda figured someone has done it but never really heard of anyone doing it. since it has been done do you know where i can look to see some specs on what they did bc id hate to dump all that money in if its going to be **** ha
Old Jun 4, 2009 | 12:01 PM
evolution253's Avatar
2.7??? I thought the highest was 2.4. I guess I was wrong. Hahah
Old Jun 4, 2009 | 12:04 PM
AF-Evo8's Avatar
the highest is a 2.6l kit from brian crower using a 4g64 block
Old Jun 4, 2009 | 12:33 PM
BoostLover99's Avatar
And that 2.6L kit from BC (which I plan on using) isn't really 2.6L
It's 2,549.5 cubic centimeters. I'll give you that 1,997 ccs (our stock engine) is close enough to 2.0L but a 50cc difference is rather significant for the anally retentive (like me).
Never heard of a 2.7L (truly >=2,700 ccs) kit and would worry a lot of rod ratio & side load on the walls.
Old Jun 4, 2009 | 01:24 PM
MrMeaner's Avatar
Say goodbye to high rpms.
Super-stroked, high revving, turbocharged engines = Fail.
Old Jun 4, 2009 | 01:42 PM
GPTourer's Avatar
This was one of the last ones I'd heard about:
https://www.evolutionm.net/forums/ev...2-7-gt42r.html
Old Jun 4, 2009 | 03:24 PM
SeanC's Avatar
The 4G64 swap is relatively common. Search "4G64 swap" or similar in the engine forum, google it too.
I chose to use the 102mm crank instead of the 106mm. This allowed me to increase my piston compression distance into a more desirable range and use a 6.000" rod (stock is 5.906"). Better combo IMO. I also kept the bore size just above 86.5mm.
Old Jun 4, 2009 | 05:02 PM
dsevo's Avatar
I'm using a 4G64, but I decided to destroke it to 94mm. IMO there are diminishing returns when you consider the advantages to larger displacement vs. the limited rpm capability. 100mm strokes typically rev about 7800-8k. A 106mm stroke would be limited to around 7500, and that doesn't even account for the really bad rod/stroke ratio.
