Help weird issue
Help weird issue
OK tonight/This morning I was almost home from work and all of a sudden I hear a popping kinda like a back fire sound from under my car. Then my Anti Lock Brake light comes on and when it would pop my ACD lights go on as well then if I got off throttle/Gas the lights go out.I got it to a parking lot turned off the key turbo timer kicked in and then when it stopped the car would not turn on no light no nothing. I then killed power from the positive terminal on my battery for a few seconds and still no power.Then all of a sudden all the lights come back on and the car tunes on and no issued the rest of the way home. I have been having a issue hitting Fuel cut due to a malfunctioning MBC "don't ask I don't know how". With this I have popped code P0141 and reset it and I have been told it was because of Fuel cut and also my Tial BOV VTA.Any help with this would greatly be helpful this is my DD. Also its a 05 Evo MR 47K miles Mods in my sig.
Thats weird man. I would check the acd and transfer case fluid. I can tell you That code is not from Boost cut. There is a right up in the ecuflash that can fix that tho.
im trying to understand this fullly
you are saying that you had the car parked. turned it off and when you went to turn the key, there was no power whatsoever? No lights, no ticking, nothing at all?
Yes it is not only electrical I can say that now since I will goto a parking lot after driveing and it will be completely dead.
