Evo VIII Entire Drivetrain Mounts, Bushings
Old Jun 15, 2009 | 07:25 AM
KazzEvo8's Avatar
I don't mean the suspension bushings. I'm pretty sure I have ALL of those. *Laugh* I've also replaced the front engine mount with a Blox piece and am very happy with it.
I'm looking for any and all options (other than OEM) for the following:
Left & right motor mounts (AMS, others?)
Transmission mount
Driveshaft "housing" bushings
Rear Diff bushings (Energy Suspension, others?)
Any other bushings for drivetrain parts (engine, trans/diff, driveshaft, rear diff)
I'd like to know who makes them and who sells them.
Thanks!
Old Jun 17, 2009 | 11:39 AM
KazzEvo8's Avatar
I'm having trouble finding the non-oem transmission mount. I can find the front motor mount. I can find passenger AND driver side mounts. But no replacement for the mount near the base of the firewall that holds the tranny.
Anyone?
I've found moustache bar bushings and driveshaft loop bushings.
Thanks.
Old Jun 17, 2009 | 12:28 PM
Kracka's Avatar
I have the Beatrush driveshaft bushings and the black (graphite impregnated aka self-lubricating) Energy Suspension rear diff bushings. I'd recomend the Beatrush diff bushings instead since they're just inserts and not complete replacements making the install a lot easier, but if you're willing to take the extra step the ES complete replacement bushings will be stiffer, you'll just need to have them pressed in.
Old Jun 17, 2009 | 10:10 PM
dambikeracer's Avatar
AWD Mororsports! www.awdmotorsports.com
Old Jun 18, 2009 | 07:34 AM
KazzEvo8's Avatar
Thanks! I already have a front. Looks like I'll be selling theirs when it gets here.
Old Jun 18, 2009 | 07:36 AM
dryad001's Avatar
Get ahold of TTP they carry Powerflex mounts, and I know for sure they carry the rear trans mount since I have one.
Old Jun 18, 2009 | 07:52 AM
Celica2EVO's Avatar
Buschur has a rear motor mount, mustache bar replacement and rear diff side mounts. Get ahold of them, all the parts work great!
Old Jun 18, 2009 | 08:05 AM
TTP Engineering's Avatar
Transmission mount
Thanks!
We have all 4 mounts in stock.
Old Jun 18, 2009 | 08:09 AM
03whitegsr's Avatar
Does anybody have the weight of the OEM mounts in comparison to the AWDMotorsports pieces?
I've got the complete rear mount (trans bracket, U shaped aluminum bracket, and 90 degree coupler link) and with hardware it's around 5.4 pounds. It seems like there might be about 10-15 pounds that could be dropped by a complete set of mounts/brackets designed to reduce weight.
Celica2Evo, do you have a link to the rear motor mount from Buschur? I can't find it on their site.
