finally drivetrain problem! 1st gear and reverse
Old Jun 16, 2009 | 10:26 AM
evilbada's Avatar
It's getting increasingly hard to get the gears into reverse and 1st gear. It's almost as if there is something blocking the gears from going in.
I literally have to "force" these gears into place.
I'm thinking the bushing?
Should I just put de-greaser on it? or change it ams/br bushing?
Old Jun 17, 2009 | 04:38 AM
evoluvinevo's Avatar
internal trans problem, bent shift fork possibly or the arm that engages and disengages the shift fork. eventually it's going to break and you'll be locked in whatever gear it breaks in.
Old Jun 17, 2009 | 08:08 AM
evilbada's Avatar
that's not good to hear..Just to add, in neutral, gears go in and out fine smoothly.
It's just 1st and reverse gears that are hard to go in at place.
Anyone else who can diagnose the problem? thanx
Old Jun 17, 2009 | 12:11 PM
evilbada's Avatar
bump for an answer
Old Jun 17, 2009 | 08:52 PM
evilbada's Avatar
bump
Old Aug 10, 2009 | 06:51 PM
EvoBrian's Avatar
got the same thing going on with mine right now. Recently did an exedy stage 2
4 puck clutch install. Used Royal Purple gl-4 75-90 for tranny. Gonna try to adjust the clutch when I get home.
