Turbo Kits.... Which one do you think
Old Jun 20, 2009 | 06:17 PM
Evo8=Life's Avatar
What turbo kit would you choose?
Car...2004 Evo
Mod List....
1. Sheppard Racing Stage 3 Transfer Case
2. Sheppard Racing Transmission
3. Triple 7 Two-Tone Paint
4. Tenzo Revo 18 Rims w/ tires
5. Eclipse AVN5510 Headunit
6. AMS Racing Intercooler
7. Megan Racing turbo back exhaust
8. Megan Racing exhaust manifold
9. ACT Heavy Duty Clutch
10. HKS 272 Camshafts
11. Rotorworks crssdrilled/slotted rotor F/R
12. Injen Intercooler Piping Kit
13. Obital Dual Din Kit
14. Buschur Racing intake
15. Greddy type RS bov
16. Stainless Steel Clutch line
17. Hawk performance brake pads F/R
18. Stainless Steal brake line
19. Rexspeed Vortex Generator
20. Walbro 255LPH HP
21. ARP head bolts
22. Weapon R oil catch can
23. Greddy turbo timer
24. Chrome UK Badging
25. Autometer carbon fiber 30 Psi Boost gauge
26. O2 sensor simulator
27. NGK Spark plugs
28. Perrin Short Antenna
29. AMS fuel Rail black
30. 680cc fuel injectors
31. 8pc Stiff Shifter Kit
31. Hyper Force
32. Hyper Force plug and play harness
33. Stainless Steal Clutch line
34. Custom Tune (Dapper Dan)
5-6,000 for the kit
(Please explain why you would chose the kit)
After the I buy the kit, i do plan on boring or stroking the engine at a later date.
Thanks
Old Jun 20, 2009 | 06:43 PM
EvoAlex48's Avatar
ya def get a new mani
Old Jun 20, 2009 | 06:51 PM
SLUG LIFE's Avatar
AFI,Shearer,AMS,etc.... Do your own research, Why in the heck would you ask people on an open forum what they want.. Build your own car!!
Old Jun 20, 2009 | 07:00 PM
David Buschur's Avatar
No problem asking. Looking at your very long mod list the parts that are important to making power are actually pretty limited.
You have basically what is in our Stages 1-4. That is the least amount of parts we suggest having before adding a turbo upgrade.
Here is what you have to do, ask yourself what your primary use for the car is going to be and how much do you like the feel of the quick spooling stock turbo? When you answer those two questions then someone can suggest a turbo. So what's your answer to those?
Old Jun 20, 2009 | 07:01 PM
scorke's Avatar
Given that you're rocking two tone paint I'm going to have to lean towards the precision 6262, if you didn't have that I would of recommended the FP Red... lolz
Best of luck!
Scorke
Old Jun 20, 2009 | 08:02 PM
dambikeracer's Avatar
400-600 WHP FP RED
500-800 WHP FP HTA 3586
I like the ETS T3 Kit:
http://www.extremeturbosystems.com/M...duct_info.html
Old Jun 20, 2009 | 08:36 PM
4G63 T's Avatar
I think with your current mods should complement stock appearing turbo.
Old Jun 20, 2009 | 08:45 PM
casper980's Avatar
what Dave said...we can't make suggestions without knowing those two things.
Old Jun 21, 2009 | 11:57 AM
Evo8=Life's Avatar
I do like the quick spool, but I what to get more power!!! I would like to find a aftermarket turbo that is still quick but can produce much more. I use it as a DD (for now), I would like to get it up to 500-600hp (Right Now)
Thanks
Old Jun 21, 2009 | 11:59 AM
Evo8=Life's Avatar
Originally Posted by dambikeracer
400-600 WHP FP RED
Look nice, I going to do some more research on it. Thanks
Old Jun 21, 2009 | 12:02 PM
FX11's Avatar
Best of luck!
Scorke
yeah since its two tone paint i def would recommend that lmao
Old Jun 21, 2009 | 01:47 PM
Well if you like the quick spool and want between 500-600 hp there is one choice for you and only one in my opinion, go with the FP Red. I also like the quick spool and I've built hundreds of EVO's with all types of turbos on them. My newest car, Project White, has the Red on it. It has made 513 whp 504 ft lbs of torque at 28 psi on the stock ECU and E85. It is for sure the turbo for your build. Awesome turbo, great spool up and you have most of what you need to run it. I'd suggest putting a SS 02 housing on the car, porting the exhaust manifold and you will need a larger injector.
Old Jun 21, 2009 | 08:21 PM
+1 ^ That's what I got and will have on and tuned as soon as my injectors get here!
Old Jun 21, 2009 | 08:29 PM
03evokid's Avatar
fp red!!
Old Jun 21, 2009 | 08:43 PM
littlegif1's Avatar
IMHO.... I would wait on a turbo and save up the money so you can do the engine and everything at once. I mean why keep going back to get the car retuned and everything. Figure out what you plan on using the car for (weekend drag, autox, etc) and then lay down a list.
Look to upgrade:
-Fuel system (injectors, regulator, etc)
- Ignition system
- Clutch (that ACT HD is not going to allow you to beat the hell out of it all the time)
You have to figure you are going to spend about $1500 to upgrade your fuel system, about $1000 for ignition and then figure another $1500-2000 for a clutch.
Just my thought
