2.3 stroker on 85mm bore?
Old Jun 21, 2009 | 10:08 PM
Evolved_6's Avatar
Ive seen alot of pistons for the 2.3l stroker on stock bore. Is this possible? I'm about to get a blockthats in perfect shape and there isnt a trust worthy machine shop around so I'd like to try stroking the motor using the stock bore. Any one tried this?
Old Jun 21, 2009 | 10:48 PM
dsevo's Avatar
You can do that as long a the cylinders are good, but you need to at the very least hone it. The rings will not seat properly without honing.
Old Jun 22, 2009 | 03:59 AM
Evo8Emperor's Avatar
4g63 block, pistons, and rods with a 4g64 crank. There's your 2.3l. You also need to check your crank clearance because its bigger. A little grinding and your good.
Old Jun 22, 2009 | 04:29 AM
Evolved_6's Avatar
Perfect , i'm aware of the honing just wasn't sure about stroking it on stock bore. Thanks for the help n advice guy.
nikush
Apr 24, 2016 03:20 PM
foxbat
Sep 17, 2015 07:31 AM
Earthen
44
Nov 10, 2009 10:50 AM
Perk77
Aug 28, 2008 07:59 PM
Derek888
58
Mar 5, 2006 07:16 PM
