adjusting tps on throttle
Can anyone tell me how the tps sensor is adjusted on an evo 8 ???
also how to adjust the screw on the throttle also ????
the car idles fine , but if u accelearte and let go , the rpm drop to 200 , and stay there for a couple of seconds , the afr go rich , and then back to normal .....
im recirculating
im recirculating
If you have Evoscan you can turn your key on; just power dont start the car; press start logging in evoscan and it will bring up what your TPS is at the moment. i just loosened the 2 screws on the TPS and turned it till it was at 100% while i held the throttle wide open, then tightened the screws down. I know you can test it with a multi meter just can’t think of the specs off the top of my head.
