ACT clutch kits..
Old Sep 11, 2009 | 10:59 AM
Chris@nolimitmotors's Avatar
The TOB that comes with the ACT kits is a OEM TOB.
Old Sep 11, 2009 | 11:24 AM
divine_evo's Avatar
I just ordered the act hdg6. I hope I'm one of the more lucky ones.
Old Sep 11, 2009 | 11:53 AM
deepee1's Avatar
Got 15K plus on my HDSS installed by TurboTrix. I changed to SS clutch line, used the stock flywheel. Still going strong.
Old Sep 11, 2009 | 06:16 PM
Neteru's Avatar
i hope you have way better luck than some of us have had.
i'm never buying an ACT kit again.
Old Sep 11, 2009 | 06:22 PM
buchnerj's Avatar
Yeah, I have heard some horror stories about people and their ACT clutches. A friend of mine with an 8 had one of their HD kits and he was getting constant lockouts at high RPMs. After doing my research about them, i decided to play it safe and spend a little more and get the Excedy Twin HD, but I am just using mine as a DD with an occasional launch here and there. I don't know why so many have problems, but others do not, all that I know is that if so many people have reported failures/lockouts/slipping something must be a little off... my 2c
Old Sep 11, 2009 | 08:35 PM
italianevo88's Avatar
oh the one that comes with it is OEM? well disreguard what i said then
Old Sep 11, 2009 | 08:38 PM
buchnerj's Avatar
No, I am pretty sure they are different. If you check out lancershop http://www.lancershop.com/customer/home.php?cat=113 they offer an ACT throwout bearing and right above it is an OEM throwout bearing.... And the ACT one is 10 bucks more than the stock one... hmmmm
Old Sep 11, 2009 | 08:39 PM
buchnerj's Avatar
A better question would be is do the OEM throwout bearings work with the ACT clutch kits? I am not sure on that one, maybe the bearing is the problem and just switching it up for a stock one will help the lockouts..?
Old Sep 11, 2009 | 09:00 PM
BoostWhore's Avatar
i thought ive read that the tob used with them is not oem... have nothing to confirm this though.... on another note I think a lot of people are running act clutches so you will probably read more about failures..
Old Sep 12, 2009 | 04:16 AM
Neteru's Avatar
when the shop was working on my tranny a couple months back...they made it a specific point to tell me that the tob that ACT provided in my kit was inadequate/weak when compared to the actual performance clutch kit it was matted to. They were surprised that ACT would provide such a meak tob they told me.
at the time all i could do was ::shrug::
Old Sep 13, 2009 | 12:52 PM
BoostWhore's Avatar
who replaced your clutch for you in orlando?
Old Sep 14, 2009 | 11:57 AM
ACT is a repackaged stock one.
Old Sep 14, 2009 | 03:04 PM
TxEvo8's Avatar
I have 93k miles on my HDSS, and I shift at 7800 while on the track. I do not drag , but I road race and have launched at least 30-40 times over the last 5 years that I've been running this clutch. No problems at all, but I think that it is getting thin, I have to press the clutch pedal all the way to the floor to shift smoothly.
Old Sep 15, 2009 | 08:18 AM
Neteru's Avatar
i forget the name of the shop but they're on south OBT.
Old Sep 17, 2009 | 09:43 PM
divine_evo's Avatar
Originally Posted by josel_atr
if you do a search, you will read bad things about act clutch kits. they will give you headaches if you dont get it installed properly.
so if installed properly they will last? I am waiting for mine in the mail so i'm concerned. i don't want to buy another clutch again so i'll be babying this one.
