Need Help
Old Jul 2, 2009 | 01:44 PM
Cali2MDevo8's Avatar
Registered User
Originally Posted by jid2
Which intake tube is on there?
Ets tube with perrin filter
jk caleb bubby. Lunch on me when i pick up my car fixed ; )
Old Jul 2, 2009 | 02:19 PM
jid2's Avatar
You may try putting the stock tube back in place.
Old Jul 2, 2009 | 02:28 PM
Registered User
Ive had the intake for 20k miles. But im sure we are willing to try anything. Thanx
Old Jul 2, 2009 | 03:55 PM
CBRD's Avatar
yeah ive thought about the tube also...
we pressure test off of the comp inlet... ill have to check the pcv return fittings and such, to see if they are bleeding from behind the maf, pre comp.
cb
Old Jul 2, 2009 | 08:38 PM
joedr's Avatar
EvoM Moderator
Injector Resistor Box. Maybe?
Old Jul 2, 2009 | 08:44 PM
joedr's Avatar
EvoM Moderator
Hi CB,
Check my other thread to see if that resembles what you are seeing on Cali's car. Here is the link: https://www.evolutionm.net/forums/ec...ease-read.html
BTW, on mine.... I ended up adding the SD Patch to rule out the MAS.
Old Jul 2, 2009 | 09:57 PM
mitsuv's Avatar
Try to datalog these values:
From the MAF: baro, karman frequency and air temp.
Engine coolant temp
map and iat if you have those.
To diagnose an injector issue log your IPW and duty.
Old Jul 3, 2009 | 06:28 AM
CBRD's Avatar
ive been logging the injector IDC's and IPW... seems normal... on both the PTE780 and the stockers we put back in.
hmmm
cb
Old Jul 4, 2009 | 07:23 AM
Registered User
Bump for anyone else that has gone through this problem
Old Jul 6, 2009 | 01:41 AM
red03evo's Avatar
bump
Old Jul 6, 2009 | 05:59 AM
SmurfZilla's Avatar
Bump for a fix for this poor soul. I have a fuel pump issue (no power)...gremlins suck
Old Jul 6, 2009 | 06:00 AM
Registered User
Thanks man ^^ Sucks not having the evo
Old Jul 6, 2009 | 06:12 AM
SmurfZilla's Avatar
Dude I never had my car. Person I bought it from sad he thinks it just needs a new ECU (Sine he was convinced the HKS FCon friend his original one. took 2 months to have shep rebuild the tcase and tranny....now I have to figure out why the FP isn't getting power.....I can believe its been such a big problem I plan on trying all the basics when I get the car to my house.
Good Luck I'll be watching your thread.....with my luck I wouldn't be surprised if I need to know what the fix is. If BRD is having a hard time thats crazy.
Old Jul 9, 2009 | 09:20 PM
Registered User
Bump. Im the only person thats had this issue before??
Old Jul 15, 2009 | 06:18 AM
Registered User
bump
