injector resistors location
Old Jul 3, 2009 | 02:25 PM
nothere's Avatar
I want to install some Bosch 1000 injectors. I need to remove the resistors from the leads.
Where are the resistors?
Old Jul 3, 2009 | 04:07 PM
CO_VR4's Avatar
The resistor "box" is a silver rectangular box about 1.5" wide and 3" long that is bolted to the firewall approximately in front of the glove box. You can't remove the resistors from the leads. You have to cut all 5 of the leads from the box and solder them together.
A DSM injector resistor box has the same plug, and costs $5-10. When you destroy your Evo one, it's about $75 to replace if you want to go back to stock at some point.
Old Jul 3, 2009 | 04:16 PM
nothere's Avatar
thanks.
