What will this do WHP wise?
Old Jul 3, 2009 | 02:54 PM
EVOIXreno's Avatar
Mods are in the Sig for now, I will be adding a Map O2 dump DP, and a Meth Kit!
on Jack of trades I Made 315/345 on 26psi on 91oct and was wondering what power increase I will get out of this.
Old Jul 3, 2009 | 03:15 PM
dunk186's Avatar
330-350ish
Old Jul 3, 2009 | 03:17 PM
dunk186's Avatar
Originally Posted by dunk186
330-350ish
sry didnt see the meth im sure it will be a nice jump thou
Old Jul 3, 2009 | 08:54 PM
SlickCT9A's Avatar
sounds about right
Old Jul 3, 2009 | 10:12 PM
cij911's Avatar
375
Old Jul 3, 2009 | 10:18 PM
BenJ's Avatar
when I had just about the same mods and 50/50 meth with 91 pump I put down 370whp and 398tq.
Old Jul 3, 2009 | 10:19 PM
Cali2MDevo8's Avatar
Registered User
you made 315hp and 345tq with 91 octate??
Old Jul 3, 2009 | 10:34 PM
BenJ's Avatar
Its definitely possible. Right now I'm making 355/355 on straight 91 on the stock IX turbo.
Old Jul 3, 2009 | 10:59 PM
dambikeracer's Avatar
you can get close to 100 WHP on meth if it's set up right. I'm thinking 375-400. Good luck
Old Jul 3, 2009 | 11:06 PM
xRoguex's Avatar
+65-85 on meth
Old Jul 4, 2009 | 11:41 AM
20psiMR's Avatar
You still wont beat me
Old Jul 4, 2009 | 01:44 PM
BLKCarbonEVO's Avatar
I will say around 370-380 on a good setup. Go read my post before you get a meth kit https://www.evolutionm.net/forums/wa...-jet-dyno.html. You may want to make sure your kit has a M10 or M15 if you want to go crazy. But remember you are replacing fuel with meth; so the higher meth injector you run the more power you will make but the more you rely on it. If your pump goes out, your motor will lean out to much and your motor may go too! Just some food for thought... You will get great gains from the M15 but that's very aggressive. I would stick with M10 for now. Good luck.
Old Jul 5, 2009 | 12:27 PM
EVOIXreno's Avatar
Yea, It took a lot of mivec tuning but it works
EVOIXreno's Avatar
We will see when you get back in town!
Old Jul 5, 2009 | 12:28 PM
EVOIXreno's Avatar
I think I will do the M7 or M10 I have both
