Hallman MBC doesnt hold?
hey guys i have the Hallman MBC that you could adjust from inside the car with the knob. for some reason the mbc isnt holding boost when i set it. it just goes all the way past 30psi. can it be that i need a new mbc? i have all the lines hooked up right too
This kit has a ceramic ball instead of the 316 stainless ball that comes in our other valves. The ceramic ball only weighs a fraction of what the stainless steel ***** weighs. This weight difference allows the ceramic ball to act very quickly as it is constantly changing directions during operation. The ceramic ball in conjunction with the use of a lighter spring will allow very fine adjustment of boost up to 4 to 5 pounds of boost over stock. Boost has been able to be adjusted in half pound increments very consistently with this valve.
If it is hitting 30psi it sounds like the ball could be sticking from machining oil. I would try loosening it all the way, and sticking something inside to try and free it.
Any other questions feel free to send me a PM!
-Brian
www.stmtuned.com
-Brian
www.stmtuned.com
yeah i have the hallman mbc pro. theres a knob and i could control the boost from inside the car.i had a boost leak test done and all seems well. hey whats the best manual boost controller out there guys?
