Evo 3, Cracked Ring Lands - Need Pistons
Old Jul 10, 2009 | 09:22 AM
dupstone's Avatar
Hi all, i have a Evo III. Engine was blowing oil and filling up my catch can. Found all 4 pistons to be suffering from ring land failure.
Have been doing some research and it seems that a common fix is to just replace them with some Evo 8 or 9 Pistons and Rods.
I am in need of some pretty urgently. If anyone can help me out and source some for me that would be greatly appreciated. New or Used in good condition would be great.
Thanks a lot.
Old Jul 10, 2009 | 09:32 AM
o7'silvermax's Avatar
hey i spoke to your cousin kevin i might have some i will let you know
Old Jul 10, 2009 | 09:54 AM
SeanC's Avatar
There is a reason the pistons failed. The EVO 8/9 pistons may be a slight upgrade, but you should consider forged pistons if you're planning on making 400hp.
Old Jul 10, 2009 | 10:07 AM
wreckleford's Avatar
Evo 3 pistons are the weakest **** in the 4g63T lineup. Even the 2g DSM pistons are stronger. The 8/9 pistons are a good budget upgrade for a 3.
Old Jul 10, 2009 | 11:16 AM
dupstone's Avatar
Cool, let me know man.
Old Jul 10, 2009 | 11:17 AM
dupstone's Avatar
Yeah, not looking for more than maybe 350 or so.
Old Jul 10, 2009 | 11:30 AM
Gary@MellonRacing's Avatar
pm me i got used pistons and rods also
Old Jul 10, 2009 | 12:03 PM
94AWDcoupe's Avatar
you will not be able to drop in 8 pistons. the bores in your block are no longer round. you will be wasting your time.
Old Jul 10, 2009 | 12:56 PM
dupstone's Avatar
The bores are fine, cylinders are in good condition.
Old Jul 10, 2009 | 02:34 PM
evo 3 r not the weakest .....
its because evo 3 have higher compression 9.01
so people satrt boosting them and boooommmmmmmm
Old Jul 10, 2009 | 03:10 PM
94AWDcoupe's Avatar
when ring lands fail the rings are no longer supported and scour the bore. the very fact that all pistons were passing oil is a direct indication of this. once the rings scour the bore the oil rings will no longer be affective. the bores may look smooth and good but they are not round anymore. if they were your oil rings would still be working fine. waste your time if you want. I am trying to give you valuable advice from years of experience from rebuilding dozens of hurt 4g63s.
Old Jul 10, 2009 | 09:01 PM
SeanC's Avatar
Originally Posted by 94awdcoupe
when ring lands fail the rings are no longer supported and scour the bore. The very fact that all pistons were passing oil is a direct indication of this. Once the rings scour the bore the oil rings will no longer be affective. The bores may look smooth and good but they are not round anymore. If they were your oil rings would still be working fine. Waste your time if you want. I am trying to give you valuable advice from years of experience from rebuilding dozens of hurt 4g63s.
+1
Igaly1021
Aug 15, 2016 07:56 PM
Charlescrown
May 5, 2014 01:58 PM
MechanicDave
Mar 2, 2011 06:52 PM
TTP Engineering
335
Jun 9, 2010 11:49 AM
turboj
Aug 20, 2007 03:19 AM
