AMS 2.3 Stroker sounds like a desiel...
Old Jul 14, 2009 | 08:16 AM
05ah8james's Avatar
I finally finished my swap and got everything all bolted up. My bottom end is a AMS 2.3 stroker, head, IM and TB is all stock. I'm also running 1200cc injectors with a 3582r.
Upon startup it sounded like a desiel! This thing sounds soooo bad. At first I though I had a bad bottom end, but I checked the oil, and there is no sign of a spun bearing. everything feels great as far as driving, but it just sounds so bad...
I did some research and I guess these ceramic coated pistons take a while to heat up and have some degree of piston slap... How do you guys feel about this?
Old Jul 14, 2009 | 08:17 AM
Philthy748's Avatar
Sound clip?
bbyevo8u's Avatar
bad in a good way?
what cams do you have?
Old Jul 14, 2009 | 08:21 AM
evoooo's Avatar
sound clip!!
Old Jul 14, 2009 | 08:23 AM
05ah8james's Avatar
Originally Posted by Philthy748
Sound clip?
Originally Posted by evoooo
sound clip!!
I'm at work and will not be home until later tonight, but I looked up "Piston Slap" on youtube, and a lot of the inline 4 cylinders that have piston slap on there sound just like my car. is this normal? I spent so much money on this build, I hope I dont need a new bottom end.
Old Jul 14, 2009 | 08:30 AM
less10's Avatar
Well you could have pistons slap if they ptw clearances are huge, and the ceramic coating isnt allowing the piston to warm up and expand like they are suppose to. Why dont you call up ams since they know the specs on your motor they should be able to help you out.
Did you buy the motor from another member or ams?
Old Jul 14, 2009 | 08:57 AM
05ah8james's Avatar
I just spoke with them and they said to send it in and they'd warrenty it. Sucks that I have to pull this whole thing back out of the car though. What a process...
Old Jul 14, 2009 | 09:32 AM
kenikh's Avatar
Warranty it? Did you figure out that there was an actual prolem? If so, what was it?
Old Jul 14, 2009 | 09:40 AM
eflove's Avatar
Did you put in a twin plate clutch when you built it? Some can be quite loud.
Old Jul 14, 2009 | 09:42 AM
Johnboy1065's Avatar
it could be out of time. or something could just be wrong in the tune...
Old Jul 14, 2009 | 09:43 AM
Danner's Avatar
Worthless without video.
Old Jul 14, 2009 | 09:47 AM
scheides's Avatar
EvoM Moderator
Is your car tuned for the 1200's? Try starting it with stock size injectors. Double check your timing and double check everythign else....do a compression test, leakdown test, and a boost leak test....do you have a massive exhaust leak?
Find the problem.
Old Jul 14, 2009 | 10:20 AM
EricJ@AMS's Avatar
Make sure it is in time. I've heard noises similar to this and it was the valves lightly tapping the pistons. Eventually one gives up and breaks the valve head off and smashes it into the piston.
Old Jul 14, 2009 | 11:11 AM
05ah8james's Avatar
No I have a ACT 6 pluck
Mellon Did the tune. I will double check with him and see if he can offer any help. Timing is dead on. Thats what I thoght it was at first, but I took everything apart and re did it and timing is dead on. Couldnt get any better.
Find the problem.
I have not done a compression test, thats an awesome idea!! I did do a boost leak test as suggested by mellon before tuning.
Yes Mellon did the scalling, and it idles fine.
I will double check for the 4th time, but I've done a lot of 4g timing belts and none have ever had this kind of result. I was so paranoid about the valve situation that I switched out the cams for stock.
The only thing I can think of is maybe I could have a **** load of bad lifters? I beld them per mitsu tech manual.
Old Jul 14, 2009 | 11:18 AM
Tsurugi-san's Avatar
Mellon is an excellent tuner --- no fault there. Is there just crazy lifter tick, or is this robbing you of power as well?
