KELFORD 272's
Old Jul 20, 2009 | 06:30 PM
bbyevo8u's Avatar
KELFORD 272's
i just had my kelford 272 & springs installed and some other mods, when i start my car it runs like stock! the car is quit and it has no lope at all? i didnt get to drive the car cause it needs to be retuned but they couldnt tune it today so i have to go back tomorrow.
if these cams are so aggressive why do they sound like stock cams
for the guys running 272 kelfords w/stock turbo-injectors, do you have any lope and does your car sound quit?
Old Jul 20, 2009 | 06:34 PM
btownsoccer22's Avatar
from my understanding the mivec smooths it out compared to the 8's
Old Jul 20, 2009 | 06:43 PM
Evo8luva's Avatar
... Mine cams out like crazy, with closed loop off to make the car run rich and like 10-12 deg timing, it idles pretty smooth. Also when I played with the intake cam timing plus what I mentioned above, I got it to idle even smoother.
It's kind of weird you don't notice any difference in idle, even at 1100rpm, my car only pulls about 11-12in vac. You might want to check to make sure the timing belt isn't off a tooth or something. But I have seen some evo9s with real calm idles with these cams...
Good luck with the tune!
Old Jul 20, 2009 | 06:44 PM
bbyevo8u's Avatar
^^ i kinda knew that but the car just sounds so quit i mean it really sounds almost stock! i have tbe w/test, exhaust tubular manifold, 02 housing, cone filter intake and the cams plus my other mods my car should not sound stock at all?!?! i just dont get it
do you guys think it have something to do with not being tuned?
Old Jul 20, 2009 | 06:49 PM
bbyevo8u's Avatar
Originally Posted by IDRINKV8'S
Are u sure there real kelfords usally there loopy,but the tuner u have is the not the best so that could be your problem
yes there def the real kelfords with the new core
Old Jul 20, 2009 | 07:28 PM
bbyevo8u's Avatar
i think Sean ivey is a great tuner! who do you thinks better then iveytune in the NY,NJ area?
more input from the guys with these cams. please
Old Jul 20, 2009 | 07:41 PM
Gary@MellonRacing's Avatar
mine sound like a hot rod ,
forcepower22's Avatar
ive got hks 272s and my car lopes a good amt
Old Jul 20, 2009 | 07:45 PM
evoluvinevo's Avatar
so to my understanding you bought these cams and were hopping for a loppy idle? who cares how "aggressive" your idle sounds. what you should be worrying about is making good power so you get your monies worth.
Old Jul 20, 2009 | 08:05 PM
bbyevo8u's Avatar
^^^ i understand that but i didnt think its normal for my car to sound soo quit?? i know these cams get lopey even in a ix but i cant understand why it sounds like a stock running car plus it was un tuned?
i dont know if its me but my car sounds quieter then before. has this happen to anyone else (ix head)
Old Jul 20, 2009 | 08:28 PM
Buddlight's Avatar
Mine is definitely not QUIET. Never heard of them being QUIET without MIVEC to smooth it out. Matter of fact, untuned they were extremely lopey and not QUIET, until the tuned smoothed it out.
Old Jul 20, 2009 | 08:29 PM
bbyevo8u's Avatar
thats what i'm talking about wtf is going on with my car???
Old Jul 20, 2009 | 08:31 PM
Buddlight's Avatar
Did you install it yourself? If not was the installer reputable? Maybe they jacked your cams and left stock in there.
Old Jul 20, 2009 | 08:34 PM
bbyevo8u's Avatar
no i didnt install them myself i had my tuner install them but they would not try and steal them they are very reputable
Old Jul 20, 2009 | 08:39 PM
magyar86's Avatar
just did a 9 with kelford 272s. Once the car fully warms up and idles down to 800ish rpm, she loped out really nice. But while cold, didnt lope at all above about 1100rpm
