After trip to chicago the clutch fails and wont start?
Old Jul 20, 2009 | 08:43 PM
YoungEvolution's Avatar
Im going to try to keep this short
I was coming back from a drive from chicago. The car drove perfect all the way there and back until i made it to a town 30mins outside of mine. I was a light and i put and first a drive normally and a loud sound comes from the tranny and it just revs freely, i tried different gears and the car just reved like the disk broke or something. So i pushed it to the nearest parking lot in the middle of traffic WTF!
So i called the towing company flat bed of couse the told me they would have to pull to a bigger parking lot which was like 5 miles away. so i sit in my car with the fmic off car in netural with it on and he pulled me there. I made it to my house about 3hrs later. The next day the car wont start UGH. So i push it into my carport and put it on jackstands. a week later i dropped the tranny and pulled the clutch. The disk was cracked and a ring that came from the Pressure plate just fell out. So i replace all of it with a new clutch. I checked everything when i put it back together all the harnesses and grounds i even installed a extra starter that i had.
And of course when i go to start it, it just cranks its turning over but wont start had 12.8 volts coming from the battery. So i check all the fuses and connections it was fine checked all my wires fine too. I thought maybe it was a line from my turbo timer to the ecu they were fine too. I checked the timing looks fine. im getting spark from all coils i pulled them and grounded them and got spark. I could smell fuel untill the last couple of starts. so i pulled the back seat and checked the fuel pump wires they were fine too but the fp was not making a nosie when i put the car in acc. I called it a quits there please help me evom im at a point or time where you just hate your evo
Old Jul 21, 2009 | 05:46 AM
20gmr's Avatar
Thats a wierd one man. you could have someone crank it for you while you use the multi meter to check for voltage at the pump. If it is getting power and not coming on then id try a fuel pump if not id start looking into that circuit.
Old Jul 21, 2009 | 07:59 AM
yeah i really hope i figure it out real soon
Old Jul 21, 2009 | 05:41 PM
I bought a new battery and still no start sounded alot better though no check engine lights are coming on during the start.so i pulled the fpr off and put a cup under the fuel rail and tried to start it to see if fuel was coming through and there was alot of it. All the plugs are good and coils too. I took the injectors off and they were pretty dirty? i need to check the crank sensor.
Old Jul 21, 2009 | 06:43 PM
1d10t's Avatar
Sounds like a cam sensor issue. What turbo manifold do you have?
Old Jul 21, 2009 | 06:45 PM
stock ported and coated
Old Jul 22, 2009 | 01:49 PM
and come to find out when im going to push start it the car still rolls in gear WTF
