Locking out between gears..
Old Jul 23, 2009 | 04:04 PM
NsinEvo8's Avatar
Ive tried searching a bit, but not enough i guess. So, when i try quick shifts from 3rd into 4th, at 7000rpm it doesnt get in gear, kinda grinds?? if i shift it at about 5-6k rpm it goes in ok. What the heck, ever since i took it in mitsu dealer for the 30k service ive noticed it. You guys think its the tranny fluid? would fluid cause this? Tia
Old Jul 23, 2009 | 04:07 PM
PATRICK B.'s Avatar
What kinda clutch are you running?
Have you adjusted it.
Normally just a fluid change won't cause an issue like that.
By the way on this forum you can just search for lockout and it will bring up thousands of threads on it.
Even EE has some i'm sure it's common.
Old Jul 23, 2009 | 04:10 PM
NsinEvo8's Avatar
exedy S1 organic
I dont know how to adjust it lol.
Thanks Pat, ill search some more
Old Jul 23, 2009 | 06:49 PM
bambooi's Avatar
Why don't you ask the dealer to fix it?
Here is how to adjust your pedal
http://evomoto.com/tech_info.php?tec...f2013a7f52f68c
Old Jul 24, 2009 | 09:57 AM
PATRICK B.'s Avatar
If ever hit me up and you can stop by the shop and i can help ya out real quick with it
Edit: never mind i forgot that you're not local to us in Union City oops.
Regardless i can always send ya pics and walk you through it.
Old Jul 24, 2009 | 11:55 AM
NsinEvo8's Avatar
Am not %100 sure it was dealers fault. Idk, rather not deal with them, they dont even have a master tech. I could of done the fluids myself, like everything else on car.. Anyhow, thanks for the link
Pat, i appriciate your offer your deserve 1st place, and yes am from monterey area, if closer id definately swing by.. If its as simple as the link above, it should be no problem. I just have to turn the rod counter clockwise to "pull out" a bit right? If there are other pics, or other method of adjusting, id love to see or read about it. Thanks
Old Jul 24, 2009 | 03:35 PM
bambooi's Avatar
My dealer replaced my 5th gear syncro. If you car is grinding, no amount of fluid is going to fix it. Only replacing the synchro will fix the problem. Now, if the clutch is poorly adjust, you may be able to fix the problem.
Good luck.
Old Jul 24, 2009 | 08:29 PM
GTijoejoe's Avatar
Good luck.
x2 adjust the clutch, still have issues, a syncro issue, certainly because of the high RPM's
Old Jul 25, 2009 | 07:02 PM
NsinEvo8's Avatar
Dam how the heck do you adjust the thing? i mean am not a skiinny guy, its tuff twistin your body to try and adjust it. laying on my back by the seat, couldnt get a grip of the rod and bolt.. i gave up with the 6in cresent wrench, try again tomm.. ):
Old Jul 25, 2009 | 08:07 PM
bambooi's Avatar
get a gear wrench you need a smaller wrench. Loosen up the small nut then you can turn the rod with your hand
Old Jul 26, 2009 | 09:07 AM
MitsuJDM's Avatar
Evomoto says that the flat spot on the rod is for an 8mm wrench. Well, on my 05 GSR, 8mm was too big. I ended up using a 1/4" wrench. Even then I didn't have enough room to "swing" the wrench, so I used small needle nose pliers. I was then able to turn it with my fingers.
I'm having high shift effort into 2nd and 4th. I adjusted the clutch and it helped very little. I'm installing my Buschur Shifter Bushings today and I have a BLOX front motor mount to put in too.
Although if it's grinding, espeically bad, it's more than likley a synchro issue. If it only grinds from time to time, it could still possible be a sychro issue OR, no offense, but it could be you.
