Need help!!!! Fried ecu????
Old Jul 27, 2009 | 05:44 AM
mitsumanny's Avatar
I was driving down the freeway and suddenly she shut off on me, I had to coast off. She will crank but not start. I also lost all communication with the ECU, the SES light wont even turn for a split second when the key is in the on position. I'm thinking this means my ECU is done, is this an accurate assessment? If not what else should I try? The plugs look about how they should for a 30K mile car and I'm getting fuel. Any help would be appreciated, also if the ECU is done what it required to replace it? Just plug in new ECU and throw in new immobilizer code? If the ECU is done for would it be cheaper to go standalone? I need her running ASAP.
Old Jul 27, 2009 | 06:17 AM
mitsumanny's Avatar
Bump need info please
Old Jul 27, 2009 | 08:05 AM
ev0lution9's Avatar
do you have a test pipe and the CEL fix on your o2 sensor?
Old Jul 27, 2009 | 08:11 AM
heel2toe's Avatar
Start checking the simple things first. Take a look at your fuses and relays and make sure nothing is blown.
Old Jul 27, 2009 | 08:13 AM
mitsumanny's Avatar
I have a gutted cat with a CEL fix for the o2
I checked the fuses but i will definately check them again
I'm under the impression that the immobilizer would not allow me to just plug in a different ECU, but would plugging my ECU into a friends car work for testing. I'm thinking the car wouldnt start but I should at least be able to communicate with the ECU if its in working condition correct?
Old Jul 27, 2009 | 08:15 AM
ev0lution9's Avatar
ok this is most likely your problem then...go under your hood check the #8 fuse with the lil engine symbol. if that is blown go to your rear o2 and inspect it most likely the wire shaved away and was hitting your chassis thus grounding out your car blowing that fuse tape it up good with electrical tape i had the same problem
Old Jul 27, 2009 | 08:19 AM
mitsumanny's Avatar
OK thanks I'll definately check this. I'm open to more suggestions as well and i'll get a list going. I'm in Houston for work and this is my only mode of transportation as well as the way i have to get home so i'll check anything and everything till its back up and running.
Old Jul 27, 2009 | 08:22 AM
ev0lution9's Avatar
yup but im willing to bet thats your problem same exact thing happened to me it would just shut off and crank but wouldnt start i found out it was a blown fuse by putting it in the on position and listening for the fuel pump and i didnt hear it so i checked under the hood and a fuse was blown
Old Jul 27, 2009 | 08:24 AM
mitsumanny's Avatar
I'm hoping its that simple but at the same time ima feel dumb cuz i had to push her in midday Texas sun
Old Jul 27, 2009 | 08:28 AM
ev0lution9's Avatar
lol that sucks! it happened to me in the rain and i have a cf hood so i thought water got in and blew my motor! just to make you feel a little bit better haha
Old Jul 27, 2009 | 08:41 AM
jdmeg6's Avatar
Check your fuses this happened to me waste gate actuator arm came across and grounded out o2 sensor. Blew the ecu fuse and car shut off wouldnt fire. Had to find a shorter o2 sensor and replace fuse. Good luck really doubt its the ecu.
Old Jul 27, 2009 | 08:51 AM
mitsumanny's Avatar
OK well thanks I'm starting to feel better. I know that the DSM ECU's had a fishy smell when they went bad is that the same with us? If its not the ECU I hope its the fuse cuz if they are both good I don't know where to take her or what else to try.
Old Jul 27, 2009 | 09:37 AM
jdmeg6's Avatar
Dont feel stupid these things happen to all of us that is how we learn and after you get it all figured out you will know how to diagnose this problem right. If it happens again you will know what to look for, part of modding things is the learning curve that goes a long with it. You can't know everything before you try it dont give up keep learning
Old Jul 27, 2009 | 09:41 AM
mitsumanny's Avatar
yea thanx, learning just hits the pocket hard lol Im trying to keep my head up about this. Worst case scenerio is bad ecu = I get a standalone
Old Jul 28, 2009 | 05:57 AM
mitsumanny's Avatar
Well I checked and rechecked the fuses and you were right blown fuse, thanx for the help I really appreciate it. I'm going to check the o2 to see if it ground up against the body I just had to go out and celebrate when the evo started up and decided to mess with her later lol. So today I'll check that and continue the troubleshooting for her original issue of wastegate boost cool!!!!
