Forge DV or stock ?
Old Aug 4, 2009 | 06:25 AM
cij911's Avatar
Forge DV or stock ?
I have a Forge DV sitting in the garage and am wondering whether I should replace my metal MR DV (non-crushed) ? The reason I did not install it, was I heard of drive ability issues. I am currently spiking at ~28psi tapering to 22psi, do the MR DVs leak at those pressures? TIA
Old Aug 4, 2009 | 06:35 AM
AWD_Terror's Avatar
the stock does not sound nearly as cool, but drives a $h!t ton better.
I removed my RS valve and put an IX one in and runs like a dream now!
I dunno if mine leaks because no matter what i set my EBC for it bleeds to 23psi on the top end as it seems yours does too. Im gonna try crushing mine a little to see if it helps, but its likely just the turbo not able to hold boost that high
Old Aug 4, 2009 | 06:38 AM
cij911's Avatar
^^ Yeah I am not trying to get my boost at redline higher as I know I would just be pushing hot air, I am just wondering if I am leaking at the DV around 28 psi....Thanks
Old Aug 4, 2009 | 07:20 AM
AWD_Terror's Avatar
do a boost leak test and set it for 28psi I guess or just crush it and see
Old Aug 4, 2009 | 12:06 PM
dantegra's Avatar
Crush your stock MR DV and you should see it hold boost better.
Old Aug 4, 2009 | 12:30 PM
scheides's Avatar
EvoM Moderator
Put on the forge, I'll give you $50 for your stock one
jk, sell the forge, the stock IX bov is the best for a basic bolt-on car!
Old Aug 4, 2009 | 12:32 PM
cij911's Avatar
^ LOL, thanks scheides...
Old Aug 4, 2009 | 12:34 PM
WannaRace's Avatar
I am still on my first generation Forge DV @ 34psi. No problems here
Old Aug 4, 2009 | 01:20 PM
sparky's Avatar
My particular MR DV cracked off the seat at just 11#. However, I think that it was a particularly wimpy example of the breed. At 28# there is no doubt in my mind that a stock uncrushed unit would be venting pretty good(bad!).
Old Aug 4, 2009 | 04:43 PM
MitsuJDM's Avatar
I had a forge. It blows wiener. APS or stock.
Old Aug 4, 2009 | 04:51 PM
ROGERV's Avatar
Im running the Forge rs, no problems and holds boost just fine.
Old Aug 4, 2009 | 05:22 PM
CoMoEvo's Avatar
if you're really concerned about holding boost on a basic bolt on set up lemme ask you this: do you have an aftermarket WGA? if not i'd say run the stocker, it may leak, but drivability will be way better.
outside of that i've heard good things about tials; however, they are only VTA.
good luck, and let us know what you route you take with a bov/dv that holds boost and doesn't leak!
Old Aug 4, 2009 | 08:12 PM
DawnoffateX's Avatar
Am I the only one that thinks the stock recirculated BoV sounds excellent? It has a harsh pushing sound, and is very loud.
Granted I have all metal pipes from IC to intake and an open element filter - but i've never seen a recirc BoV as loud as mine is. I'm happy with it and the cars drive ability is excellent. If it leaks, that's a different story. However, i'm content.
A tial, although nice - would make you run rich as they are only VTA on a MAF equipped vehicle.
Old Aug 4, 2009 | 09:14 PM
jid2's Avatar
The Forge will hold boost and drive like crap at part throttle. That's all you need to know.
It takes 5 mins to install - see if you like it. I ditched my Forge for an APS and haven't looked back, holds boost and drives nice.
Old Aug 4, 2009 | 09:24 PM
cij911's Avatar
Thanks for the feedback guys....
