Is there any mods for fuel economy?
Old Oct 11, 2003 | 10:02 PM
STC's Avatar
STC
Question Is there any mods for fuel economy?
The Evo fuel economy sucks. My fiance gets about 230 miles per gallon like most people here.
She said she read in a recent SCC or some other car mags that they did some Project Evo and one of the mods was for fuel economy. She told me that their EVo went from 16 mpg to about 20 mpg.
Anyone know what shes talking about?
Old Oct 11, 2003 | 10:14 PM
teknotikal's Avatar
brain reflash. ECU reflash i would imagine
Old Oct 11, 2003 | 10:29 PM
Quickshift's Avatar
Tear out the turbo , only thing i can think off
and no i am a subsriber and have followed scc for yrs , espescialy since the evo came out and i have never seen any article of that nature.
Old Oct 11, 2003 | 10:45 PM
SAEVO's Avatar
SAFC II or some sort of reflash where you lean it out, the EVO runs too rich all through the RPM range
Old Oct 11, 2003 | 10:47 PM
bobaab's Avatar
drive under 3000 rpm and dont let the boost kick in
Old Oct 11, 2003 | 11:12 PM
pjal84's Avatar
https://www.evolutionm.net/forums/sh...+lean+and+loop <---ShapeGSX explains it pretty simply why that will not work.
Old Oct 11, 2003 | 11:14 PM
Hungbee112's Avatar
Grounding Kit!
Old Oct 11, 2003 | 11:56 PM
teknotikal's Avatar
hey thanks for the link. quite infomative.
Old Oct 12, 2003 | 12:08 AM
sophis's Avatar
There are those magnets which attach to the fuel lines. A lot of the Japanese evo owners site that I visited used such things and have said it worked somewhat. One such thing is the Top Fuel POWER NEO. Your guess is as good as mine to whether or not those things really work.
Old Oct 12, 2003 | 03:27 AM
MaxR's Avatar
synthetic for the trans and transfer would help
Old Oct 12, 2003 | 05:00 AM
ozlancer0z's Avatar
drving under 3K should do wonders
Old Oct 12, 2003 | 08:03 AM
berkel's Avatar
Whatup,
Here are a few things that helped me:
-run a tad more tire pressure to reduce rolling resistance.
-Don't drive with your windows or sunroof open, although I mostly ignore that one.
-As stated synthetic drivetrain fluids (tranny, transfer case, rear diff, and of course motor).
I get about 21 mpg, and refill my tank (~12 gallons) at ~250 miles. Not great, but better than when the car was new, when I barely got over 200 miles per tank.
Oh, the K&N seemed to help a little bit as well. I'm installing an SAFCII, which may not help per the thread above (just waiting for my harness from Z1) and a muffler delete pipe (Bushur most likely) so that may help as well.
Thoughts?
FB
Old Oct 12, 2003 | 08:15 AM
SilverEvo8owner's Avatar
With my full turbo back without a cat and grounding kit i noticed better gas mileage
Ill be getting greddy e-manage soon so that should help out a lot
I cant get 280 on one tank of gas
Old Oct 12, 2003 | 03:32 PM
90GSX-03EVO's Avatar
Put in a MBC and set it to 11 psi.
That should work.
hehe.
Josh
Old Oct 12, 2003 | 03:38 PM
MalibuJack's Avatar
Actually, most of the same mods we do for performance also improve gas mileage.. I was getting about 225-230 miles on a tank of gas.. Now I generally get 270-300 miles to the tank.. Also driving without getting into boost as often as possible and running the correct tire pressure helps a bit..
