need help with cel 172 and possible BBK hotside leak
Old Sep 19, 2009 | 10:09 AM
  #31
vmrevo9's Avatar
Veteran: Air Force
good point^^^
good luck guys!
Old Sep 19, 2009 | 10:52 AM
  #32
CBRD's Avatar
Originally Posted by Cali2MDevo8
Could something be wrong with the BR ported IM that was installed? I know you changed out my Mil spec TB, but what about the IM?
Jason,
aside of it leaking somewhere because of a crack or other, i cant think of something that would be a problem, and we replaced all of the sensors attached to it..
errrrr
cb
Old Sep 19, 2009 | 11:58 AM
  #33
vmrevo9's Avatar
Veteran: Air Force
i wonder if its worth trying.
Old Sep 19, 2009 | 01:56 PM
  #34
cij911's Avatar
try replacing the 02 sensor...(the sensor may be getting damaged during the install process)...
Old Sep 19, 2009 | 02:07 PM
  #35
CBRD's Avatar
We replaced primary and secondary
Old Sep 19, 2009 | 02:20 PM
  #36
cij911's Avatar
Chad - Does the car throw a 172 with a stock turbo and tune ?
Old Sep 19, 2009 | 04:07 PM
  #37
Cali2MDevo8's Avatar
Registered User
Stock tune is on the car. BBK is still on the car. I ran the BBK for a while before I had this issue. Only possible changes that could be made is putting on a stock turd and stock IM. Waiting on Joedr to change out his resistor box to see if it helps him.
Chad, I know its frustrating for both of us. Thanks for sticking with it.
Old Sep 19, 2009 | 04:42 PM
  #38
addo's Avatar
i haven't got ecu scan so i can really check but when i was at the Nurburgring recently the engine light came on after while so checked the pipe work shut the bonnet and it went off so it was alright although it felt sort of lumpy and not as driveble. i came back and spoke to my mapper and he thinks its the fuel trims after cruising alot. i'm running RC 1000's. i'm getting a tweak next week, i'll let you know what we find.
Old Sep 19, 2009 | 05:50 PM
  #39
Registered User
^^its not my fuel trims or boost leak witch are the primary causes of p0172 codes on boosted vehicles : /
Old Sep 19, 2009 | 07:52 PM
  #40
EVO8LTW's Avatar
If you force the car into open loop (using the periphery bit or through the load/tps tables), (1) does it still set the code, and (2) is the AFR close to stoich?
Old Sep 19, 2009 | 08:10 PM
  #41
Registered User
I actually asked chad to try this a few weeks ago. Dont think chad has tried it.
Old Sep 20, 2009 | 02:02 AM
  #42
kiley_sean's Avatar
I can't offer you any assistance, but can relate to your frustration.
I have had the 0172 code for over a year now. Checked vacuum/boost leaks, cleaned MAf, plugs all that Jazz. It happened after a couple weeks of modding (TExedy twin clutch, EVO IX BOV, ARC airbox, First road tune)..so it's hard to tell what caused it. He didn't mess with injector trims since they were stock injectors.
Strange thing is the code will go away when I have A/C on. It will stay off for weeks during the Summer when the A/C is on, but as soon as I turn the A/C off, the code will reappear after about 20 miles.
The p0172 seems to be an elusive code to diagnose and cure from what I have read on this forum. I feel you pain.
Rexpeed
Evo 'For Sale' Exterior Styling
166
Sep 26, 2018 11:06 PM
EvoKnievo
Dec 30, 2016 02:35 PM
evol911
Northwest Region
23
Jun 15, 2011 11:04 PM
jan_ralliart
Toronto Lancer Club
11
Mar 14, 2011 06:57 AM
strife
36
May 12, 2009 08:01 AM
