Boost levels for a fp red ?
Old Aug 14, 2009 | 07:19 PM
mantosride's Avatar
Well my red will be here next week, I was wondering what is a safe psi to run ?
I dont care about pushing the turbo to its max, I want to be safe, and I want my 06 MR to last.
I have the following mods to date
AMS TBE
AMS FMIC
AMS LICP
K&N filter
Megan 02 housing
injectors 880's
AEM wideband
boost controller.
Old Aug 14, 2009 | 08:14 PM
partyboy1122's Avatar
Bro you made a similar post already. Pump your fine running anywhere from 20-27psi. At least 25+ to wake the turbo up.
Old Aug 14, 2009 | 08:23 PM
Xearo's Avatar
you can run 32 to 84.2 psi and be allright.
Old Aug 14, 2009 | 08:31 PM
Xearo's Avatar
that will really "wake up" your turbo =) and your neighbors too!
Old Aug 15, 2009 | 07:09 AM
cij911's Avatar
All in the tune...you should be fine in the 27/28 peak psi range on 93, but again it will depend on your car and tune...
Old Aug 15, 2009 | 08:14 AM
Gary@MellonRacing's Avatar
get a good tuner first , then hill add more boost if ur motor can handle it
ive seen mellon do 30pounds on 93pump , its all about the correct mods , and good a tuner
Old Aug 15, 2009 | 08:15 AM
dammm that will wake me up :lol
Old Aug 15, 2009 | 10:21 AM
JKD's Avatar
JKD
Tune and fuel octane will govern the amount of boost you can run.
Old Aug 15, 2009 | 11:22 AM
DJ Brett B's Avatar
Cams would really help as well....
Old Aug 15, 2009 | 12:07 PM
Draven83's Avatar
and head studs
Old Aug 15, 2009 | 12:10 PM
slowr_evo's Avatar
kelford 280's son ftw!
Old Aug 15, 2009 | 12:34 PM
mantosride's Avatar
How about gsc s1's
Old Aug 15, 2009 | 01:15 PM
Xearo's Avatar
will the bottom end be safe besides the head studs?
Old Aug 15, 2009 | 01:27 PM
Jim in Tucson's Avatar
Add E85 to your mod list if you really want to get your money's worth out of the new turbo.
I would not worry about the head studs. Our engines don't grenade from boost, they grenade from knock. You've heard it before, and its true: It's all in the tune.
Old Aug 15, 2009 | 04:23 PM
evo4life400's Avatar
i just got my tuned and i am at 26 psi and my tuner said i can probably do a couple more pounds but you definitely need some cams and headstuds to be safe and maximize the potential
