Fp red budget build what is needed???
Old Aug 18, 2009 | 08:36 PM
ilikeppie's Avatar
Question Fp red budget build what is needed???
So i am thinking about throwing a red on my evo but i am wondering what all i have to have and what all would be good to have to do this. Thanks
Old Aug 18, 2009 | 08:39 PM
localtoys73's Avatar
https://www.evolutionm.net/forums/ev...93-octane.html
Old Aug 19, 2009 | 08:12 AM
JKD's Avatar
JKD
Give us your current list of mods and we can give you better advice.
Old Aug 19, 2009 | 09:44 AM
William254's Avatar
i would say the fp oil line kit and the kit to the turbo can fit the evo 8. other than that its all up to u for the power u want
Old Aug 19, 2009 | 09:30 PM
ilikeppie's Avatar
i have 272 cams, tbe, e85 tune, hard piping and a few other misc mods
Old Aug 19, 2009 | 09:40 PM
ilikeppie's Avatar
would i need double fuel pump for e85 n fp red?
Old Aug 19, 2009 | 09:57 PM
ilikeppie's Avatar
do i get the 1st gen or 2nd gen kit for the install on a evo8
Old Aug 19, 2009 | 10:48 PM
xxNosTankxx's Avatar
2nd gen but call FP theyre very helpful
Old Aug 20, 2009 | 12:43 AM
William254's Avatar
yes u will most likely need a double pumper on e85. i would go 1200cc injectors and a full blown double pumper!!
Old Aug 20, 2009 | 03:37 PM
ilikeppie's Avatar
what do you mean by full blown double pumper? is there a diff than just a double walbro?
Old Aug 20, 2009 | 04:48 PM
CO_VR4's Avatar
Full Blown makes a CNC's top hat fuel pump assembly, which is used instead of modifying the stock assembly. That is what is being described in the post above yours...
Old Aug 20, 2009 | 05:45 PM
scheides's Avatar
EvoM Moderator
What size injectors do you currently have?
If you're on a budget, do the CBRD BBK instead. You'll end up spending about $400 less and make just as much power with better bottom-end; that's enough to do a ported exhaust manifold, o2 housing, and all new gaskets/copper washers.
You'll max out 1000cc injectors and single pump, but they'll definitely work. Do FIC 1250's and you'll have plenty of fuel.
Comparo of my car vs a friend's car, BBK vs RED:
http://www.scheides.com/gallery/evo-...6_30_2009_0011
(red line is BBK, green line is fp red)
boost plot:
http://www.scheides.com/gallery/evo-...6_30_2009_0012
So yea, no fancy oil lines or intakes needed, just a basic install kit.
Old Aug 20, 2009 | 06:22 PM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
If you plan to do E85 you will need at least 1200cc injectors, you will need a form of a double pumper(he said budget), and if you don't have one I would go with a 3.5 IC only because of the altitude only because when heat soak takes place on a hot summers day the thin hot air will make the car feel like crap. I would also suggest you PM red owners like myself and tuners and ask what they would suggest. What are you HP goals, what do you do with the car....you have to ask yourself these questions too to make a good decision
Old Aug 20, 2009 | 07:00 PM
l2r99gst's Avatar
boost plot:
scheides,
Can you list the mods of the two cars involved? I'm shopping around for a new turbo and I would like to start getting a good comparison going.
Old Aug 20, 2009 | 08:36 PM
CO_VR4's Avatar
If you're on a budget, do the CBRD BBK instead...
I think that Scheides is a BBK owner who loves his turbo and never misses a chance to diss a RED. You'd be hard pressed to find anyone else who would say that a BBK makes equivalent power to a RED... it just ain't so in the rest of the country...
