Fp red not sure how to tell a 80mm!
Old Aug 19, 2009 | 07:55 PM
mantosride's Avatar
Okay so i found a used fp red that i want to buy he is telling me that this is the 80 version, how can i tell if it really is ?
thanks for the help
Old Aug 19, 2009 | 08:03 PM
inco9nito99's Avatar
Compare it to your stock turbo. The 80mm compressor housing is NOTICEABLY larger than your IX turbo. If it is not, you have standard FPRed.
Old Aug 19, 2009 | 08:07 PM
Fp3052's Avatar
Go to this website
www.forcedperformance.com and they have a picture on there of their 80mm cover
Old Aug 19, 2009 | 08:09 PM
KenMasters's Avatar
Use a mic.
Old Aug 19, 2009 | 08:15 PM
EvoLutionized8's Avatar
it is noticeably different. surge openings around the housing is a dead giveaway
Old Aug 19, 2009 | 09:13 PM
project_skyline's Avatar
Whip out your *****, the opening should be bigger then it. The stock one is about the size of your current one.
Common now give me a break, did you goto school? Ever heard of a ruler!
Old Aug 19, 2009 | 10:04 PM
MOREPSiTEHBETT4's Avatar
Originally Posted by KenMasters
Use a mic.
isn't that overdoing it..just a lil, a ruler would do just fine
Old Aug 19, 2009 | 10:05 PM
Ruthless.'s Avatar
um, 80mm/3in. take a measuring tape, measuer the inlet and there ya go. not rocket science.
Old Aug 19, 2009 | 10:43 PM
xxNosTankxx's Avatar
really? measure
Old Aug 20, 2009 | 07:30 AM
Steve93Talon's Avatar
You don't need to measure anything, you can tell from across the room whether it's got the 80mm cover or not.
Standard IX comp. housing:
80mm FP cast housing (note FP stamp and larger surge ported inlet):
Old Aug 20, 2009 | 08:51 AM
ROGERV's Avatar
Old Aug 20, 2009 | 08:53 AM
dbsears's Avatar
Think somebody better invest in bifocals...if you can't tell the difference between those housings I would worry about your choice of women...I keed
Old Aug 20, 2009 | 09:40 AM
JKD's Avatar
JKD
Those pictures sums it up!
Old Aug 20, 2009 | 01:05 PM
turbo addict's Avatar
ya, ported shroud inlet and FP cast into the compressor housing. not just stamped into the plate.
Old Aug 20, 2009 | 02:28 PM
Gary@MellonRacing's Avatar
make sure its a fp red and not the fp rojo 80mm made in china
