misfire
Old Aug 22, 2009 | 07:16 AM
vugy79's Avatar
Question misfire
ok here is the deal my 06 was running fine untill i went to iraq for 15 months while i was gone it was hardly drivin and now that i have it back im having all kinds of issues it all started with a code for the variable valve timing overadvanced and mitsu told me that it needed a new ecu due to a tune that wouldnt take a reflash the car had a manual boost controller i had off so the dealer wouldnt see it ive put that back on and that issue hasnt retured but now im getting the dreded P0300 and the car stumbles around 3000 to 3500 rpm my tuner was data logging while this was goin on and it showed no knock at all it looked as if the ecu just trips out and forgets where its at we did find the throttle body shaft seals were bad and i replaced that but still have the issue i also replaced the plugs and am waiting for new wires it does not do it every time usually once its warmed up any suggestions would be very helpfull thanks
Old Aug 22, 2009 | 07:18 AM
vugy79's Avatar
ohh i forgot the car has cams in it i dont know what they are since they were in the car when i got it the car acted fine on the dyno making peak hp at around 7000 rpm it seems to do this on the road i also found that the transfer had no oil in it for i dont know how long ive since filled it and ordered a new stage 2 from shep trans
