HELP Bolt Fell Out While Driving!!!!
Old Aug 25, 2009 | 12:26 PM
  #31
zbomb's Avatar
Originally Posted by yooyooyoo
did u check ur lower shock bolt, the one below the eccentric camber bolt? Kinda looks the right sizeish
+1
Old Aug 25, 2009 | 02:40 PM
  #32
R0b's Avatar
R0b
downpipe to 02 housing bolt?
although, i would have expected this bolt to be a bit rusty...it looks every similar though..
Old Aug 25, 2009 | 02:46 PM
  #33
Clutchdc5's Avatar
it could be a random bolt from sombodies else's car u ran over...
Old Aug 25, 2009 | 04:36 PM
  #34
BLKCarbonEVO's Avatar
This would be ideal but I doubt it.... I have the worst of luck.
Old Aug 25, 2009 | 09:53 PM
  #35
SLO-EVO's Avatar
theres no way... it doesnt have the "built on washer"...
any results on your findings yet?
Old Aug 25, 2009 | 11:41 PM
  #36
I'm actually at work right now but I'll check the bolt size when I get home tomorrow and I'll try to look under the car. I can't get it to a lift till thursday.
Old Aug 26, 2009 | 04:46 AM
  #37
SLO-EVO's Avatar
you know finding the measurements for the bolt ie .85 pitch, w/ length will help
Old Aug 26, 2009 | 05:10 AM
  #38
I know the bolt has an 8 on the head
Old Aug 26, 2009 | 05:19 AM
  #39
ethan169's Avatar
i think that 8 just means its grade 8? Figure out what socket size fits on it for starters. 14mm 17mmm etc...
Good luck. I hate it when this happens, well this and when you lose a bolt or washer or something. Never fails no matter how simple a job something will fall down into the engine bay making my 15 min job an hour job
Good luck!
Old Aug 26, 2009 | 05:36 AM
  #40
tkklemann's Avatar
Good luck!
No such thing as a Grade "8" Metric bolt.
Metric grades are generally 5.8, 8.8, 9.8, 10.9, 12.9.
Knowing what socket size it takes is a huge help because most of us who work on our cars regularly know what whench sizes go where for which bolts.
Old Aug 26, 2009 | 06:34 AM
  #41
BigBiLL011's Avatar
Judging by how clean it looks i would say upper engine bay somewhere...bottom side usually picks up road grime, brake dust, etc.
Otherwise go with what 4ws said and check every thing u have recently removed/loosened for mods
I dont know if ur motor mounts were direct replacements or not but it could be an extra not needed for the new that u dropped during disassembly...longshot i kno
Old Aug 26, 2009 | 07:13 AM
  #42
ethan169's Avatar
Good call! Thanks for the correction.
and +1 on it prob being from upper engine bay because being such a clean bolt.
Old Aug 26, 2009 | 01:06 PM
  #43
I found were the bolt came from. It was in plain sight the whole time! I was just overlooking it. It was off the cross member. Thanks for all the help!
Old Aug 26, 2009 | 01:40 PM
  #44
tkklemann's Avatar
Subframe bolt.
Oh shoot, it was a subframe (Cross member) bolt!!
Do I win a prize?
Old Aug 26, 2009 | 01:46 PM
  #45
Do I win a prize?
BZ and a Job Well Done!
Thanks
